Question about Measuring Tools & Sensors
I have a oil drain error code. I replaced the oil drain solenoid only to discover I have no power going to the solenoid. I remove the circuit board p/N 539664 and discovered it has a non-serviceable
Would this be the only component that could cause this issue? The circuit board that is. M
  • 11 Answers
SOURCE: Bosch SHU4300 Water Fill Issue.
Similar problem for us turned out to be water accumulating in the tray which set off the float switch.  I vacuumed the water out and function returned to normal.  However, we are now facing a repairman's assertion the clay in our well clogged the water inlet systems necessitating $285 in repair parts and labor.
Posted on Oct 13, 2007
Bubbabear64
  • 2794 Answers
SOURCE: AA Battery Drain...just discovered a 3V battery in my camera
Usually the 3v battery holds the date and time in your camera. A lot of time with digital cameras you have to remove the batteries when there not in use for a long period of time to prevent the draining from happening.
Do you have regular AA batteries to see if the meter changes? That would be the best way to see it the camera is reporting the correct battery life.
Posted on Dec 05, 2008
  • 122 Answers
SOURCE: Miele dishwasher did not drain. Discove
Yes - the dishwasher drains into the disposal - if the disposal is blocked up - it will hamper the dishwasher draining.
Posted on Jan 05, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: gas in block of briggs 18 hp engine
Replace the gaskets on your motor. You are going to have to buy a gasket set in order to complete this. As long as you have not tried to start it, you will not have any other issues with your engine. But if you have tried to start the motor then you can possibly of hurt the valves or the piston. So if you did not try to start it then just rebuild the engine with the gasket kit, and everything will be fine after that
Posted on Jun 03, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Was receiving E68 code on
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Posted on Aug 17, 2011
Can the input speed sensor on a 2009 GMC Acadia be changed without having to remove the transmission
Did you do the diagnostic's that go to that code ?
DTC P0717: Input Speed Sensor Circuit Low Voltage
Diagnostic Fault Information
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Signal Performance
Input Speed Sensor Supply Voltage
P0717
P0717
P0716
Input Speed Sensor Signal
P0716, P0717
P0716, P0717
P0716, P0717
P0716
Circuit/System Description
The input speed sensor (ISS) is a hall-effect type sensor. The sensor faces the 1-2-3-4 and 3-5-R clutch housing machined teeth surface. The sensor receives 8.3-9.3 volts on the input/output speed sensor (ISS/OSS) supply voltage circuit from the transmission control module (TCM). As the 1-2-3-4 and 3-5-R clutch housing rotates, the sensor produces a signal frequency based on the machined surface of the 1-2-3-4 and 3-5-R clutch housing. This signal is transmitted through the ISS signal circuit to the control solenoid (w/body and TCM) valve assembly. The control solenoid (w/body and TCM) valve assembly uses the ISS signal to determine line pressure, transmission shift patterns, torque converter clutch (TCC) slip speed and gear ratio.
Circuit/System Verification
Engine idling, observe the scan tool Transmission ISS parameter while varying the engine speed. The Transmission ISS parameter should change with the engine speed and not drop out.
Operate the vehicle within the Conditions for Running the DTC to verify the DTC does not reset. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Ignition OFF, remove the control valve body cover. Refer to Control Valve Body Cover Replacement.
Connect the TCM harness connector.
Disconnect the input speed sensor (ISS) from the control solenoid (w/body and TCM) valve assembly.
Connect the J 38522 between the supply voltage terminal B and ISS signal terminal A at the control solenoid (w/body and TCM) valve assembly. Refer to Control Solenoid Valve and Transmission Control Module Assembly Input Shaft Speed/Output Shaft Speed Input Test for further instructions.
Set the J 38522 signal to 8 volts, the frequency to 120 and the percent duty cycle to 50.
Ignition ON, observe the scan tool Transmission ISS parameter. The scan tool Transmission ISS parameter should be between 100-400 RPM.
? If not within the specified range, replace the control solenoid (w/body and TCM) valve assembly.
If all circuits test normal, test or replace the input speed sensor.
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection.
Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement.
Remove the oil cooler inlet hose (1) from the retainer on the control valve body cover.
Remove the oil cooler outlet hose retainer nut (5) from the control valve body cover.
Remove the oil cooler outlet hose (4) from the retainer on the control valve body cover.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle.
Remove the left engine splash shield. Refer to Engine Splash Shield Replacement.
Drain the transmission. Refer to Transmission Fluid Replacement.
you don't need to pull thr trans .
Feb 19, 2017 | GMC Cars & Trucks
2003 Ford Focus 2.3
Chris, you did not state auto or man. transmission. If auto check fluid level, if low top up. If still slipping and fluid OK, a transmission tech. will have to look at it and diagnose.
If manual trans. clutch is either worn out or oil has gotten onto its surface, in either case a transmission tech. will have to look at it and diagnose.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 06, 2016 | Ford Cars & Trucks
2009 cummins isx cm871 fualt code mid 128 sid 372 fmi 1
[PDF]Fault codes .pdf - heavydutypowertrain.Com
www.heavydutypowertrain.com/md200codes.pdf
Description. Sample Fault Code Chart. Sample Display. 128. PID/SID FMI. MID. 110. 003 ... MID 128 - CAT. CAT. PID/. SID. FMI Fault. Code. Fault. Description. 1. 11. 72..... Injector Metering Rail #1. Cummins (Continued). PID/. SID. FMI Fault. Code ...372. Fuel Pump Control Module. 12. 374. Fuel Pump Control Module. 13.
2009 Volvo ISX Cummings Codes ' TruckersReport.com Trucking Forum ...
www.thetruckersreport.com > ... > Volvo Forum
Sep 13, 2013 - Well my truck finally stopped today and has these 6 codes. Anyone have any idea what they are? MID 128 SID 380 FMI 11 MID 128 PID 131 ...
[PDF]Diagnostic Fault Codes For Cummins Engines - Allied ...
www.alliedsystems.com/pdf/Wagner/Forms/80/80-1044.pdf
Dec 18, 2015 | Cummins Signature ISX QSX15 Series Service...
Error code list
ALARMS THAT STOP THE DISHWASHER
A1 Want of water
Is the water cock open?
Does the water load solenoid valve work?
Is the water feed flow a min. of 5 l/min?
Is the water inlet filter clean?
Is the load solenoid valve filter clean?
Is the overflow inserted?
Do the tank/boiler pressure switches work properly?
C9 Automatic hood out of order
Alarm codes for automatic hood type dishwasher (see paragraph 9.2.1 Alarm codes for automatic
hood type dishwashers)
C12 Tank level sensor out of order
Are the connectors correctly connected?
Are connector contacts cleaned?
Does the air trap of the tank work correctly?
Is the level sensor broken (replace it with a new one)?
Alarm codes for automatic hood type dishwashers
When the alarm C9 appears, to facilitate fault-finding a parameter providing a more detailed indication has
been introduced.
The parameter is C9 and is found in the ron family.
The possible cause of the anomaly can be found (see next table) according to the value of the parameter C9.
E.g.: With an automatic hood type the alarm C9 appears.
Access the parameter C9 in the ron family.
Assuming the value displayed is:
20 ? During lifting, the current absorbed by the lifting motor has exceeded the threshold. This can happen if
a rack or other heavy material was placed on the hood.
ALARMS THAT DON'T STOP THE DISHWASHER (SHOWN ON THE USER INTERFACE AT REGULAR INTERVALS)
b1 Drain not efficient
Has the overflow been removed?
Is the water drain blocked?
Is the drain pump blocked?
Are the air trap and tank pressure switch clean?
Is there a constriction in the drain tube?
Is the pump breather pipe returning to the tank clogged or constricted?
Does the tank pressure switch work properly?
Is there a hole in the drain tube (only for versions with drain pump)?
b2 Overflow alarm
Is the load solenoid valve blocked? (see electrical wiring diagram - YV1 Filling solenoid valve)
Is the load solenoid valve relay stuck? (see electrical wiring diagram - RL5 relay of AP2 board)
C1 Boiler temperature rise too fast
Does the boiler level sensor work properly? The boiler could be empty.
Are no-original power resistances installed?
C2 Boiler temperature too high
Has the boiler temperature been changed (btC - increased above 90°C)?
Has the software alarm value been modified (bH,)?
Boiler relay/relays sticked (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board)?
C3 Tank temperature too high
Is the feed water above 60°C?
Has the software alarm value been modified (tHi)?
Is the rinse water temperature too high?
Is the tank relay stuck (see electrical wiring diagram - RL4 relay of AP2 board)?
C4 Tank temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST1 Tank
probe)?
Is the temperature sensor connector correctly inserted?
C5 Tank temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST1 Tank probe)?
C6 Boiler temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST2 Boiler
probe)?
C7 Boiler temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST2 boiler probe)?
C10 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor broken or disconnected?
C11 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor short-circuited?
C13 Rinse pump out of order (the water level of the boiler does not decrease)
Does the rinse pump work correctly?
Is there any bottleneck in the hose, that connect the air trap and the board sensor?
WARNING:
Alarms C2, C6 and C7 lock the boiler temperature control.
Alarms C3, C4 and C5 lock the tank temperature control.
In the case of alarms C6 and C7, the boiler waiting phase is not executed (the rinse may be performed
with cold water) and, during the initial warm-up and subsequent rinses ( btF > 0 ), the boiler heating
phase is not executed.
In the case of an open probe error ( C4, C6 e C10 ), the displayed temperature is 10°C
In the case of a shorted probe error ( C5,C7 e C11 ) , the displayed temperature is 99°C.
E1 Communication error
Is the connection between main board and control panel correct? Are the connectors correctly
connected?
Are connector contacts clean?
E2 Tank temperature low
Does the tank heating element work properly?
Are the dishwasher feed voltage and current correct?
Is the relay RL4 (see electrical wiring diagram - RL4 relay of AP2 board) on the board disconnected
or faulty?
E3 Boiler temperature low
Does/do the boiler heating element/s work properly?
Does the possible remote control switch connected to the heating element work correctly?
Is there power at the remote control switch input terminals?
Do boiler relays (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board) work properly?
CAUTION: IF THERE IS A MALFUNCTION ON RELAY RL1 AND THE BOILER HEATING ELEMENTS
ARE FED BY MEANS OF A REMOTE CONTROL SWITCH, THE BOARD DOES NOT
HAVE TO BE REPLACED; JUST MOVE THE BOILER HEATING ELEMENT CONNECTOR TO
ONE OF THE TWO FREE POSITIONS ON THE BOARD.
CAUTION: WHEN ONE BRANCH OF THE HEATING ELEMENT DOES NOT WORK AND THE
OTHER TWO CONTINUE TO FUNCTION, ON REACHING THE SET TEMPERATURE VALUE,
ALARM 3 DISAPPEARS AND REAPPEARS IN THE SUBSEQUENT RINSE PHASE. THIS
ALSO OCCURS WHEN A PHASE IS MISSING.
Dado
Sep 01, 2014 | Zanussi Dishwashers
I changed the 3-4 shift soleniod but now i dont have any gear but 2nd and before we had 1-3 just not over drive. what could have went wrong?
There is no code that tells you to replace the shift sdolenoid. There is a code (P0783) That has a generic description of "3-4 Shift Malfunction". Please note that there are several things that can cause this code. This code DOES NOT mean to replace the shift solenoid without first diagnosing the other possible causes of this code.
P0753 is for the "3-4 Shift Solenoid/Transmission Relay Circuit" If this is the code you had, please note that this code is a CIRCUIT code. The circuit includes the 3-4 shift solenoid, the transmission power relay and all the the wires and connectors connecting the power relay, the solenoid, and the PCM together. In this case the CIRCUITS must be diagnosed prior to replacing ANYTHING.
With all that said, is there now, or was there originally any other codes in the system besides one of these? If so, what are/were they? It is possible that there is a relay fault that is causing ALL of the shift solenoids to malfunction. It is also possible that there is low line pressure causing your no-shifting problem. Then there is the question: Are you absolutely certain that you replaced the correct solenoid?
I have also seen the shifting problems worsen due to misdiagnosis. Example: the power relay is causing the problem...the 3-4 shift solenoid gets changed...the transmission valve body is now full of air because the transmission was drained and the shift solenoid was removed from the valve body causing the valve body to drain...everything gets put back together and the transmission fluid is replaced....Now the transmission will not shift in any gear because the valve body cannot purge the air due to the solenoids being inoperative. They were inoperative in the first place and are still inoperative because the wrong part got replaced. PROPER diagnosis and repair will get everything working again.
I would recommend starting over to see what codes you now have and diagnose the system accordingly.
Sep 23, 2011 | 1999 Dodge Durango
Whirlpool washer machine, F02 code on the display it says on the book is a drain problem, how can be fixed?
It sounds like the drain pump may be bad. Does the washer initially start, or do you get the code right away? If it does, listen for the draining water sound, you'll probably get the code at that point.
There are 3 possibilities: bad pump, bad solenoid, bad control board. of the cuff i'd bet on the solenoid first. But you don't want to shotgun the thing. IF washer starts a cycle, listen to hear the click of the solenoid. No click and error code, i'd go with the board. If the solenoid clicks , then the control board is likely good.
Hope this isn't too much info. If you don't have a mechanical experience, it may be a little hard.
Let me know
Jan 09, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hobart lx 18 does not drain
I'm assuming you're not seeing any error codes such as E0, E1, E2, etc. which could be related to water level probes. Be sure all probes are clean, free of lime/scale buildup which can interfere with the machine's water level detection.
For this machine to drain, three things must happen:
1. Drain solenoid must energize and pull in to actuate the drain body.
2. Drain body then redirects pumped water to the drain hose instead of to wash arms.
3. Pump must run and pump water out.
Remove the lower-front access panel (2 screws). The Drain body is the plastic L-shaped part with two hoses attached. It is visible on the bottom side of the dishwasher, centered in the machine both Left-to-Right and Front-to-Rear. The Drain solenoid is immediately to the front of the drain body.
When the machine is supposed to drain, watch the solenoid and drain body. If the solenoid pulls in and the pump runs, but pumps water to the wash arms instead of out to the drain hose, then replace the drain body (drain body is usually to blame when draining problems occur).
If the solenoid does not pull in when the machine is suppose to drain, then unplug the solenoid connector and test the solenoid coil resistance with a multimeter; you should get a resistance of, I'm just guessing here, approximately 1000 ohms, maybe. At any rate, you should have some reading on the meter, not and open circuit. It you get no resistance reading, the solenoid is bad - replace the solenoid.
Mar 01, 2010 | Hobart 24 in. LXIC-5 Built-in Dishwasher
What do the F1 & F2 failure codes on my HE3T washer, mod. #110.42926200 indicate? The washer shut off in mid-cycle and began flashing F1. After pulling the electric plug and reconnecting (2 minutes), I...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 22, 2009 | Kenmore Washing Machines
Measuring Tools & Sensors Logo
37 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
