Konica minolta bh215 CCF01 error code. Kindly give me the proper solution in english.
5 Suggested Answers
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Konica minolta bizhub 215 Error Code CCF01
no luck in the service manual for that one please recheck
Jul 14, 2014 | Konica Minolta bizhub Office Equipment &...
Error code ccf01
One of the rarest machines in the Konica Minolta line up!!!!!
A printer without a control panel. the code deal with one control board not talking to another, recommend a tech look at it he might be able to re-flash the firmware the copiers operating system worse case one or both boards are bad. Is the machine on a good surge protector not an Ace hardware 9.99 special? Nothing against Ace. But a thousand dollar machine should be protected with a good minimum 100 dollar surge protector.
Dec 30, 2013 | Konica Minolta bizhub C450P Laser Printer
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
94 people viewed this question
jasbo
jasbo
