Question about Cuisinart Bfp-10ch Powerblend Duet Blender/food Processor
When i attached with jar the bled is not moving and i could not able to grad so anyone know which part do i need to change. please I have PowerBlend Duel Blender/Food Processor - BFP-10CH is working
Blendar
    Habit-Forming:
  • 16 Answers
Sounds like the bearings on the blades have seized. Replace the blade assembly by unscrewing the bottom of the jar.
Posted on Nov 14, 2014
1997 mercury sable gs 3.0l replaced master brake, still having brake pedal feeling spongy and slowly traveling down. i bench bled master brake and bled brake right rear left rear right then front.
If the master cylinder is replaced, care must be taken to prime the new master cylinder by removing all of the air and completely filling it with brake fluid. The spongy feeling is air that is still in the circuits. You will need to bleed the back brakes as well as the front ones again. The order that you bled them seems correct, but perhaps there remained some air in the main trunk lines.
For the best results 2 people are needed. Start at the further distance wheel cylinder and bleed at least three (3) master cylinder reservoir volumes of fluid (back brakes). Bleed the fluid with use of a piece of tubing attached to the bleed port that is long enough to reach almost to the bottom of a long neck or tall clear jar (clear drink bottle works well). When the bleeding begins, after one or two brake pedal pushes, make sure that the end of the tubing is below the surface of the fluid and keep it under. It best to have a clear bleed line (to observe air). Keep pumping the brake pedal while being careful to not completely empty the master cylinder reservoir (leave 1/4 full always). Repeat the same technique for each wheel cylinder with at least two (2) reservoirs full for front brakes. Partially close the bleed ports when almost finished (at least 5 pedal strokes without exit of any air). Completely close the ports during the down stroke of the brake pedal, with the tubing still attached. Be sure each bleed port is closed snuggly.
Most of the brake fluid can be reused, but not the darker portion at the bottom of the jar.
Oct 09, 2016 | 1997 Mercury Sable
Replaced m.cylinder &booster on our 92 Grand Cherokee, bled several times& still don't have much pedal, doesn't grab until almost to floor, it will stop, but don't feel safe driving. Suggestions?.
Hello Susan,
You will have to have the brakes (especially the front ones) bled continuously until the air that is trapped in the lines comes out!
Brake systems use about 2/3 of the available braking power sent to the front wheels and that is why the front ones must be fully bled before you will notice any changes in the stopping /brake pedal feel.
Start with the wheel closest to the master cylinder and work your way around the vehicle. Front left, front right, rear left, then finally if needed the rear right.
Rich Lilja
Apr 02, 2015 | Jeep Grand Cherokee Cars & Trucks
My HP-12B calculator is in grad mode I need to be in deg, how do I change ?
Is there a button marked DEG->? That is the standard calculator button used to change mode. It could possibly be the shift function of another button.
Mar 05, 2011 | HP Office Equipment & Supplies
Changed brake pads! Success.. Now I need to bleed the brakes.
To bleed you brake system, you will need brake fluid, a jar, and a couple feet of small hose that fits tightly on the bleeder screws. You should not need to remove the tires to access the bleeder screws, but you may need to raise the vehicle a bit to access them.
To bleed the system, start with the right rear wheel. Put a couple inches of brake fluid in the jar, attach the hose to the bleeder screw, put the hose in the jar of brake fluid, then open the bleeder screw. Once the bleeder screw is open, pump the brake several times. Next, close the bleeder screw. After you close the bleeder screw, remove the hose and jar, then fill the master cylinder with brake fluid.
Repeat the steps going to the left rear second, right front third, and left front last.
Once you have bled the system your brakes should be tight and working nice.
I hope this information helps you, and I wish you luck on your repair.
May 10, 2009 | 1995 Mercedes-Benz S-Class
Now I can only count in Degrees and radians
Press the MODE button to enter the Mode menu, and change the angular measure to suit.
Mar 25, 2009 | Texas Instruments TI-83 Plus Calculator
Clutch on the jar of my cbt500 cuisinart blender is broken.
The clutch assembly is for the teeth on the base itself. If your problem is with the teeth that are connected to the bottom of the blade that sits in the jar, you want to order a blade assembly instead.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 21, 2009 | Cuisinart Blenders
Used Dario grad-o-meter D400
I just bought a used dario gradometer and it's by inches. 8056845136 I will sell it to you.
Feb 16, 2009 | Classic Electronics Measuring Tools &...
Spongie brakes
Gravity bleeding doesnt usually work real well.
Get a clear jar of some type, and a piece of 1/4 inch vacuum hose about 18 inches long. Put about 2 inches of new brake fluid in the container.
Start at the passenger rear wheel, losen the bleeder, slide the hose tightly over the open bleeder, the other end in the jar where you can see the hose end.
Fill master cylinder reservoir.
Pump brake no more than 4 times, watching the hose end in the jar for bubbles. After 4 pumps, check reservoir, refill. Pump 4 more times. Watch for bubbles. Check reservoir, pump 4 more times. If you see bubbles at any time, then keep going through the above steps until you stop seeing bubbles.
Go to rear wheel, tighten bleeder. Go to driver rear wheel, and do the same thing, although this time it won't take but 4-6 pumps to purge any air.
Go to passenger front, repeat.
Go to driver front, repeat.
Do not recycle any of the fluid.
Jan 28, 2009 | 1991 GMC C1500
Cuisinart Bfp-10ch Powerblend Duet Blender/food Processor Logo
71 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
