Question about Xante Ilumina 502 GS Digital Color Press laser toner
What happens if you pull a paper jam from feeder, the opposite direction that your support to?
    Sergeant:
  • Xante Expert
  • 286 Answers
There are usually a number of paper guides and sensor arms that will tear into the paper if pulled the wrong way.
This can leave paper fragments in the fuser causing further jams, temperature sensor malfunctions, or odd marks on the print, and small pieces of paper left in the fuser usually require disassembling the unit to clean it out.
At worst case one or more sensor arms could be dislocated or broken which can be difficult or expensive to replace.
Posted on Jan 11, 2015
What happens if you pull paper jam the wrong way
You may break any of the plastic switches actuators, which could cause a problem and your printer would not work until you replace that part that is broken. Depending on what area of the printer you broke the problem will be shown on your printer pannel.
Nov 12, 2014 | Xante Ilumina 502 GS Digital Color Press...
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    Stylus CX9400 Photo Printer: paper jammed inside printer...
    May 18, 2010 | Epson Stylus CX9400 Photo Printer
    My indicator is showing a paper jam and I have cleared all paper that I can see from the feed area. It still instructs to clear the paper jam. Do I need to try to get inside the box and if so - how should...
    Once some printers report paper jam, you most must go through certain procedures, even if you have removed the jammed paper, for the printer to print again. So I suggest you follow this procedure:-
    i. Put off the printer and unplug it from its power source.
    ii. Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
    iii. Site the paper (if any) that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer’s mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
    v. Close all covers at the top, front or back.
    vi. Power on your printer and you should be able to print again.
    Dec 19, 2009 | HP J4680 Office Jet All-In-One Printer
    How to clear paper jam in HL 5040 laser printer
    Clearing paper jam in a printer is simple almost seven step procedure.
    i. Put off the printer.
    ii. Open all the covers/shutters on the printer (usually one in front or top and one at the back.
    iii. Now pull out the cartridge carefully.
    iv. Site the paper that has jammed and pull it out in the opposite direction of its movement. (Pulling the paper in the opposite direction is important for the printer mechanism).
    v. Return the cartridge and press it firmly inside.
    vi. Close all covers.
    Dec 04, 2009 | Brother HL 5040 Laser Printer
    COPIER WONT COPY AS LITE INDICATES PAPER JAM DON'T SEE ANY PAPER AT ALL
    Hello sir; Go back to wherever you pull out the paper, because you pull the paper in opposite direction therefor pull off the senser,go back where the paper jam put the senser back in right position.
    May 30, 2009 | Sharp AL-1655CS Copier
    Paper shifts
    Does it happen both off the copy glass & thru the document feeder or only off the document feeder. If both - check the side guides inside the cassette to make sure they are tight against the paper. If it only happens when using the feeder- the feeder tray needs to be adjusted. There is usually 2 screws under the document tray that when loosened allow for side to side adjustment. Moving the tray should solve the problem if it is only happening when you use the document feeder.
    Mar 30, 2007 | Canon imageRUNNER 2000 Copier
    Xante Ilumina 502 GS Digital Color Press laser toner Logo
    65 people viewed this question
    Top Xante Office Equipment & Supplies Experts
    Ottoniel
    Dudeman321
    CheckitRight
    CheckitRight
    Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
