I have a samsung NP355U5C-A06UK laptop i have connected this to my tv with a hdmi lead but it says no signal on my tv and on the laptop it doesnt come up as my tv connected. What am i doing wrong
    Habit-Forming:
  • 16 Answers
Click the Fn key together with the f4 key on your keyboard to toggle between monitors.
Posted on Nov 14, 2014
5 Suggested Answers
SOURCE: "No Signal" Message when using HDMI Inputs on 26" Proscan LCD TV
You MUST get HDMI Driver for your Video Card, it is NOT standard. You need to go to PC makers web site and download latest Video Divers for your PC, then you must set up Multiple Desktops, To do that you must first connect the TV, but leave OFF, connect up to PC, reboot, setup Video Card, turn ON TV, TV will have already been detected, On PC, Share the desktop, or Clone, whatever you wish, now reboot after saving settings. Now you set the TV for HDMI already and it should show you a desktop when chosen. You must select and setup TV, FIRST, then connect the PC. From then on, Turn the TV ON, then turn the PC ON, that way it will Always detect the HDMI port.
Posted on Apr 23, 2010
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
  • 127 Answers
SOURCE: I have a Samsung Series 6-650 LCD TV (Model #
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Posted on Mar 02, 2010
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
I do have a lg BH6430P home theatre,when I connect the HDMI to the TV it gives me no signal
check that the hdmi lead is good, if it is check that its outputting a signal that is not too high for the tv. i.e. if the lg is outputting 1080p can your tv show 1080p just because the tv is HD ready, doesnt automatically mean it can show 1080p try setting the lg to 720p or lower to see if anything shows on the tv
Aug 02, 2017 | LG Audio Players & Recorders
VGA CONNECTION TO A SAMSUNG TV NO SIGNAL
have you tryed re,tuneing your tv to see if it finds your vga cable.
or try going into your av menu on your tv and it should give you a list of ext1 or ext2 and so on.or try hdmi 1.hdmi 2,and so on.
May 23, 2014 | Samsung N Computers & Internet
Lg 42lt75 used to work with a bp630 blue ray player but now shows "No Signal".
have you tried connecting ur laptop via hdmi to tv? if it works you should probably check tv settings for hdmi, if not then it is possible that the hdmi controller from tv to have some problems, i had a similar problem with a philips tv and took it to service ending up in a total replacement of motherboard and led display
Mar 09, 2014 | Televison & Video
Problem with Dell W4201C 42 in. HDTV Plasma Television
Plug the HDMI into laptop and T.V first then turn the laptop on, I have the same problem sometimes just doesnt read it properly if the laptop is already turned on when plugging in to HDMI. Hope this helps
Sep 05, 2012 | Dell W4201C 42 in. Plasma HDTV
Dell laptop connected to yamaha reciever via hdmi no picture or sound?
This has to do with your video driver on your laptop that needs updating.
go to Control Panel\All Control Panel Items\Windows Update
download any updates from here.shutdown laptop, check the cable connection from laptop to tv then restart.
If still no luck try another hdmi cable
Nov 25, 2011 | Dell Studio 1537 Laptop
I bought an hp laptop and a sony hdmi cabel so i could be able to use my laptop on the lcd sony bravia tv. i connect my ps3 as well on the hdmi ports. at first everything was fine. no it doesnt work. i...
if you constantly change between one type of unit to another. say between your ps3 and another type of device then you could have worn the connector on the hdmi socket. it may need to be replaced. thats the best I can do. we have a bravia but dont change connections at all because it can cause many issues over extend use especially if youre changing devices whilst the set is on, as this can interfere and damage the internal circutry which may have shorted out the hdmi circuits.
Sep 11, 2010 | Televison & Video
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
