Question about Bosch 1999 Dodge Ram 2500 Van Water Pump
Waterpump has three hoses 1-upper 2- lower 3-? where does third hose go
Need to know where the center hose from water pump goes
  • 3,506 Answers
Possibly heater if is is a smaller hose
Posted on Nov 15, 2014
WOULD SOFT WATER HAVE A BAD EFFECT ON THIS MODEL AS IT HAS RUSTY BITS
Hot water heaters are a collector of sediment. The proper care includes flushing out the collected debris through the low side drain faucet. The problem is the faucet is not designed correctly to carry out the needed task. If you are handy... turn off the water and gas or electricity to your water heater. Relieve the water pressure through the temperature/pressure relief valve on the side of the water heater tank. Once pressure is relieved close the valve. Determine if you have a 1/2 inch or a 3/4 inch diameter drain valve hole in the side of the tank where the drain valve is located. The drain valve can be removed with channel lock pliers, an 8 or 10 inch adjustable wrench, or a small 8 to 10 inch pipe wrench. Water will leak out the threaded hole while the valve is out. If everything is closed maybe 2 cups of water will leak out of the hot water tank as you check drain valve thread size. DO NOT take your time checking thread size. After you know the pipe thread size go to the hardware store ( Home Depot, Lowe's etc) purchase a short nipple (1 1/2 to 3 inch depending on available space) and a ball valve (brass) due to the water temperature. You will also need a brass adapter for pipe thread to garden hose thread (male both ends). This adapter goes into the ball valve to allow for the connection of a garden hose. Connect the pipe and valve together using the correct pipe thread sealant and install in place of the original plastic drain valve. Install pipe to hose adapter using thread sealant. With the ball valve in place turn the water back on. Gas or electricity back on. Connect a garden hose to the ball valve. Place the other end of the garden hose in a safe area as hot water and debris will be expelled through the hose. With water on, Gas or Electricity on and the relief valve closed actuate the ball valve to the full open position for approximately 3 seconds then close the valve. Repeat the open and close of the ball valve three times. Observe the debris that emptied out of the garden hose. You may be surprised at what you see. If the water runs clear, disconnect the garden hose the task is completed. You can wait until the following year to repeat the process. Your pipe and valve are now a part of the water heater, they may remain in place. Put the hose away.
Aug 31, 2015 | Water Water Heaters
Whirlpool Cabrio Washer fills but will not do anything else
1. Remove the drain hose from the drain and try to drain the water from the washer. To do this plug the washer back in and attempt another drain cycle. If water does not come out of the drain hose then you now know that the plumbing is in good working order. 2. Place the drain hose back into the drain and remove the washers cabinet.
3. You will now be able to see the pump and it should have two hoses attached to it.
4. Disconnect the hose coming from the basket. If water comes out you will know that nothing is clogging the basket.
5. If both of these tests come out good you now know that the problem is the pump.
6. Make sure you write down all relevant information such as the washing machine model and serial number.
7. Head to your local hardware store and buy a pump (they typically run about $15.00).
8. Remove the old pump and install the new one (make sure the washing machine is turned off and unplugged).
9. Test it. Let it run through a cycle to make sure everything is installed and working properly.
10. If it is still broken call a repairman or ask a handy friend to check it out for you.
Sep 20, 2012 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
How do I wire around upper heating element until I can get an other one to replace it?
Question posted under marathon electric water heater.
Marathon is 240Volt dual element non-simultaneous water heater.
Non-simultaneous means that upper part of tank has to reach temperature before power is sent to lower thermostat and element. So if upper element is bad, then water heater has no hot water.
http://waterheatertimer.org/Replace-anode-rod.html#audibleBW
1) You need to by-pass upper element without by-passing upper thermostat.
2) You should never by-pass upper thermostat because it has ECO-reset protection.
http://waterheatertimer.org/How-water-heater-thermostats-work.html
3) Open following link for image of wiring:
http://waterheatertimer.org/images/Marathon-wiring-700.jpg
4) Take photo of your wiring in case color code is different on your specific model
5) Look at upper thermostat.
Remove yellow wire from terminal 2 on upper thermostat, and cap off temporarily.
Remove red wire from terminal 4 on upper thermostat, and move it to terminal 2 on upper thermostat.
6) For more effective operation, look at lower thermostat.
Remove black wire from lower thermostat terminal 1 and move wire to terminal 2 on lower thermostat.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Rheem MR105245 Marathon Electric Water...
HOW TO REPAIR A LEAKY INSINKERATOR HOT WATER DISPENSER...... Found the following at another website when looking for a solution to my leaky hot water dispenser. Worked great for me, so wanted to share the...
What if you back the temp down to say 165 or so would that not keep the plastic from frying?
Also does that model not sit ambient until hot water is needed and is not "hot" 24/7/365 as you
stated? Just wondering.
Feb 06, 2011 | Emerson Water Heaters
How to drain71- 40 .where is drain need to replace hearer need to drain first. 50 gal
There is usually a spigot right at the base of the water heater. Thread a garden hose on the spigot and route the garden hose outside. Of course be sure to pull the power breaker first. After you are sure that the power is off, turn the spigot handle and let the water flow. Be sure that you turn the inlet valve off that is located on the top feed pipe. Be sure to turn the feed back on before you power up as this will ensure that the upper and lower calrods are covered before you power on.
Jan 22, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I awoke to no hot water, my heater is three yrs old and i just changed my upper and lower element and upper thermostat, still no hot water then i checked to see if i was getting power and i am, is there...
Your water heater has 2 elements so its 240Volts.
1) If breaker is delivering power on one leg of the 240Volt circuit, then water heater can appear to have electricity, but tank is receiving 120V. Both 120Volt legs are needed to complete the 240V circuit. Double check for 240Volts.
2) Review electric Load.
Water heater label shows wattage of tank.
If tank is 4500Watts for example, you installed 3500 or 4500 watt elements.
With 5500 Watt elements you need 30 amp breaker and orange-colored 10 gauge wire
With 4500 Watt elements you can get by on 20 amp breaker and 12 gauge wire up to 75 feet away.
3) Check ECO red reset button on upper thermostat. If reset is tripped, then ECO is reading high temperatures. Suspects at this point are defective upper thermostat, shorted wire or bad lower element.
4) Also note that insulation and cover must be re-installed over thermostat. Thermostat reads temperature through wall of tank. If outside air circulates around thermostat, that can cause a mis-read and cause tank to overheat and ECO trips.
If you don't want to test the heater, replace both thermostats for about $25. Return the upper thermostat for a refund. Then see of problem persists.
Here's what I would do.
1. Check breaker for 240
2. Check water heater for 240 across 1 and 3 screws on upper thermostat
3. Note wiring and breaker size.
4. Note label on side of tank.
5. Look at end of new element to see wattage printed on each element. Look for sings of high heat and burning. Tighten screws on elements.
6. Check ECO reset button. Look for high-heat and burning. Tighten screws on thermostat.
7. Test upper thermostat as follows:
http://waterheatertimer.org/images/Electric-diagram-water-800.jpg
Test left-side #1 screw to right-side middle #4 screw. Test should read 240V at all times. If not, then ECO is tripped, thermostat is bad, or electricity is OFF
8) Water heater is cold so upper element should be ON. Test upper thermostat.
Test right-side #3 screw to left-side bottom #2 screw and it should read 240V
Test right-side #3 screw to right-side bottom #4 screw and it should read 0 volts
8. If upper thermostat checks out. Test upper element for 240 across both screws. If upper element does not read 240 when water is cold, then element is bad or there is a shorted wire between element and upper thermostat.
How to test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
9. Do a full troubleshoot on electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 07, 2010 | General Electric GE SmartWater Household...
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
Sep 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
I am trying to drain my electric water heater: Servistar, model no.06443 serial no.0496B02329, watt: 1-PH,Upper 4500 240 volts only, Lower 4500 Cap. U.S. Gallons 50 Total 4500 I closed the cold water...
Hi Karen, think of the water heater as a straw....if the straw has liquid in it and you put your finger on the top, the liquid doesn't come out. If you open up the relief valve, air will allow it to flow freely. The relief valve has a metal lever on it, usually on the top of the water heater (if electric).
Feb 06, 2010 | RTO Home Heating Products 5.5HH240...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Bosch 1999 Dodge Ram 2500 Van Water Pump Logo
47 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
