Question about Garden
Can I run the engine dry of gas without putting the water on,for winter storage.
Trying to get it ready for winter,with out hauling out the hose to hook-up the water.
  • 2,355 Answers
Yes
Posted on Nov 14, 2014
z34aga
  • 137 Answers
SOURCE: Output pressure same as input pressure.
check the presure regulation valve after you are sure that isnt damaged from ice.
Sulejman Sulejmani
Posted on Mar 26, 2009
  • 15 Answers
SOURCE: I have a Briggs & Stratton gas power washer. This
Sounds like the unloader is not working correctly. Try replacing it and see what happens.
Posted on Apr 23, 2009
  • 272 Answers
SOURCE: engine will not run
There is no fuel pump it's purely gravity feed. At the bottom of the carb should be a bolt with a nut on it loosen the nut and start backing this out it is actually a needle valve and they frequently get corroded and need to be cleaned. Fuel should be coming out of the bottom of the carb, reinstall it and try again. If it's still not working your float may be stuck, or your carb is gunked up. I'd pull the carb get a carb kit and rebuild it. It's about a twenty minute job. Or take it into a mower shop and have them do it if your not comfortable trying. Gas won't flow out on the cylinder side unless you have a problem gas has to be sucked out of the carb by the negative pressure in the engine.
Posted on May 12, 2009
SOURCE: Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Posted on Aug 14, 2009
  • 332 Answers
SOURCE: hooked it up with water started engine and no
Your water system is plugged with "gunk"
You will need to slush it out with water and air pressure if you can until it runs clear
Posted on Apr 04, 2010
How can i get condensation out of gas
Hello Gary William Hill Sr.,
Water in the fuel is really more common than you'd imagine... in reasonable quantities is no problem that cant be easily handled.
Amazon, Costco or your friendly Chevron Station... (below)
Any alcohol based (most of them) fuel additive will absorb minimal amounts of water... and pass quite harmlessly through (MOST) fuel systems
(all MY caution is about 25+ vintage vehicles).
The alcohol "absorbs" the water... Running gas with methanol should also accomplish the deed for you... assuming you have a MODERN METHANOL capable fuel system.
If it is an OLDER CAR (vintage)... been sitting around... avoid the
MODERN METHANOL stunt... bad idea...
(eats old style fuel lines... among other things).
But all winter (above water) should NOT pose any major issues.
If you want to be super careful shoot a little penetrating oil into your SPARK-PLUG holes before turning on that ignition.
Purists...
The fool-proof way is to drain the bottom of the tank (preferably) before any corrosion starts (routine preflight fuel check).
Hope this helps... Work/Drive safely.
Apr 03, 2016 | Cars & Trucks
Tip
Winterizing a Washing Machine
If you keep your washer in area where you need to winterize for the winter (unheated garage or unoccupied vacation home), the following steps may provide you with some helpful guidance in preparing before extreme temperatures occur and possibly leave you with damaged plumbing and/or a ruined appliance.<br /> <br /> <b><u>TOP LOADERS</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub, and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. STOP or CANCEL the timer on the washer and UNPLUG.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. Clean the detergent dispenser and fabric softener dispenser and ensure they are dry.<br /> <br /> 8. Store washer, unplugged in an upright position.<br /> <br /> <br /> <b><u>FRONT LOADER</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. Press PAUSE/CANCEL twice to halt the cycle and UNPLUG the appliance.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. IMPORTANT: Check the perimeter of the door bellow (gray rubber seal) and make sure no small articles of clothing are left in the rubber folds. Clean this area thoroughly and dry. NOTE: Anything left behind will mildew over a period of time causing foul odors.<br /> <br /> 8. Clean the detergent dispenser drawer of any remaining water or fabric softener residue.<br /> <br /> 9. Store washer, unplugged in an upright position.<br /> <br /> <b><i><u>Secondary Method</u></i></b>: <br /> <br /> If you cannot find RV antifreeze (or prefer not to use it), another method of draining the washer is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. This will pull any remaining water from the drain pump and lines. <br /> <br /> If a shop vac is not available, lowering the drain hose from the standpipe to the floor will allow it to drain using simple gravity. <u>IMPORTANT</u>: On a front loader, you may have to remove the drain line from the drain pump to drain the pump. Or, use the access cover (if equipped). Most front loader pumps are accessed by removing the lower panel directly below the door.<br /> <br /> <b><i><u>Taking the Washer out of Winter Storage</u></i></b>:<br /> <br /> To remove antifreeze from the washer following storage, run the appliance on a complete cycle with detergent and NO garments added.<br /> <br /> I hope you find this information helpful. If you have any questions, please let me know.<br /> <br /> <br />
on Aug 09, 2011 | Washing Machines
Tip
How to store your motorcycle for winter. Storing your motorcycle.
As the summer months start to come in, we all like to get our motorcycles out and start riding them, but i hear a lot of people saying help, my bike wont start! That is because when you last parked it in the shed for the start of winter, then you made no preparations. With a few simple steps, next summer, you can get your bike out, and fire it up without any problems, ready to ride. There are things you must do when you go into storage, and a few things to do when you bring your bike out.
OK,so winter is approaching, and you want to put your bike away in the shed.
First thing you need to do is drain some fluids. Drain your engine oil. Then drain your gas tank and carburetors. It is important to drain the carbys, as the fuel left in the float bowl will go bad. You can choose to totally drain your gas tank, or fill it to the top with gas. Storing a tank full with gas, leaves no room for moisture to form, causing rust on the inside of steel tanks. Next, you need to also disconnect one lead from your battery, or even better, if you have a trickle charger hooked up to it. Thats about it really. Also,if you are confident in doing so, remove spark plug, or plugs, and spray some penetrating oil down into each cylinder, turn engine over to work it through. This will prevent any moisture or corrosion from forming on the inside of your cylinders. It is also a good idea to clean or replace your spark plugs each year anyway.
Now it's summer, and you want to ride, just roll your bike out. Put in some fresh engine oil, a fresh tank of gas, and a fully charged battery, you are ready to go!
on Jun 21, 2010 | Motorcycles
Craftsman lawnmower won't start after winter storage
Try to put a little gas in the sparkplug hole.Put plug back in then try to start again.
Feb 20, 2015 | Craftsman Garden
How do I winterize my 2003 Winnebago Minnie?
You need to blow the all ware lines clean with a air gun nozzle. Empty/ drain all water storage units and pour windshield washer fluid or pool safe antifreeze in toilets and let stand. I would remove all batteries and stored with a 2Amp trickle charger until spring
Jan 02, 2015 | Cars & Trucks
John deere lx188 water cooled engine. Do I need to winterize it or keep it from freezing?
Your tractor should have come with a blend of antifreeze just like a car. You can go to any auto-parts store to get a tester and see what temperature your coolant will freeze at is. As long as that temp is lower than your local chills you're good in that department (it is very important as freezing water will crack a block, or radiator, or plastic hose connections)
I also strongly recommend that you fill your gas tank fully and add seafoam or some other winterizing additive to your fuel before filling it to ensure you don't get water build up in the tank and that it doesn't gunk up in the carb. Some also like to just run it out of fuel completely. I personally don't like to let me seals dry up this way. I will sometimes put a vice grip on the fuel line after the filter to stop the fuel then run the engine until just the carb itself is empty.
In general, unless you have access to fuel with ZERO ethanol, it is bad to let these engines sit without running for more than a few weeks at a time. The carbs on these small engines are not designed to handle modern fuels with ethanol and the ethanol fuel seems to quickly turn into a coagulated mess in the carb's fuel bowl. I like to run mine every 2 to 3 weeks even if it's just to warm it up for 20 minutes all year even when I'm not using it.
I also strongly recommend a battery tender. A single winter without running will ruin these smaller batteries, especially in cold temps, a battery tender will resolve this problem. If you don't park near an outlet, just remove the battery and put it near one. :) .
Nov 11, 2013 | John Deere Starter Tractor Lx188 Kawasaki...
Engine runs for 2 seconds until the gas runs out. I did change diaphrams , plug , filter and cleaned gas tank out. Murry 22" with no-throttle gas. Will start but will not run unless gas is put in...
I think you should put some thought into soaking the whole carb in cleaner fluid. seems the little passages for fuel are plugged and should be blown free with pressurized air after a good long soak. this happens with age, especially if the thing sits over winter or other long periods with no stablizer put in the gas before storage. gas turns into a lacquer like substance without the stabilizer.
Aug 25, 2011 | Garden
Lawn mower runs and then putters down, won't die but runs slow.
clean the air filter,wash out in turps if foam type,then wash in soapy hot water,then rinse,let dry,then put litle bit of clean engine oil in it,squeeze.drain all fuel,and put fresh in.may have to pull carb to bits and blow out,and reassemble.put new spark plug in.is it a briggs engine,or tecumseh?
Jul 11, 2010 | Garden
I would like instructions on how to drain the carb for winter storage
Please do this: Get a fuel stabilizer such as StaBil, from your auto parts or motorcycle shop place. Go to the gas station, put the amount of stabilizer required in yourf tank, then fill the tank. Go for a little ride. When you get home, turn off the fuel valve. Let the engine run until it stop (runs out of gas). Store your bike in a cool, dry place.
Thanks for your interest in FixYa.com
please vote
thanks
a
Dec 05, 2009 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
Aug 09, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
