Question about Garden
I turn the key and hear 1 click and nothing else
    Problem Solver:
  • 22 Answers
Number 1, make sure the battery is good and both cables on it are tight, make sure the deck isn't engaged, if both of those are ok, and if you have a meter or a test light unplug the small wire off the solenoid, ( to find the solenoid follow the positive cable from the battery) put the meter or test light onto the end of the small wire, then try to start the engine, if you have 12 volts to this little wire then either your solenoid or starter is bad, if you don't have 12 volts to it then you have a safety switch issue. If you have a 12 volt source you can touch the terminal on the starter to test it to see if it is good, turn the key on and you can also start the engine this way but not recommended as a fix..
Posted on Nov 14, 2014
I can hear it click but it wont open with the key either.
Auto Repair : Power Door Lock Troubleshooting - YouTube
? 1:52
https://www.youtube.com/watch?v=wsqbE_ztTYw
May 12, 2009 - Uploaded by ehowauto
Hi i have a locked driver side door that will not open.when i lift the locking ... I press the power lock, and hear a sound but all four doors remain locked or unlocked ... Hey sorry for the botherbut I need help.my key button don't unlock or lock.the button inside the car doesn't work either to unlock or lock.so I'm ...
Fixing A Car That Does Nothing When You Turn The Key ...
? 3:37
https://www.youtube.com/watch?v=TSE0fOrujW0
Aug 16, 2012 - Uploaded by Scotty Kilmer
2005 Mustang wont start or crank from the key.. wont say nothing good battery ..... all I hear is clicking noise my radio and lights and everything comes on but it will not do nothing what couldthis be have I blown something?
Jan 06, 2016 | Cars & Trucks
How does the seat on a 2005 Triumph S3 open
you need to turn the key more almost 1/4 turn you will hear a click from the back of the seat
Jul 05, 2012 | 2005 Triumph Speed triple
1993 Jeep Grand Cherokee cranks well but will not start. I hear nothing when I first turn key on.
You hear nothing? It cranks well? I'm not sure if I understand what you are "listening" for. Do you hear the starter cranking the engine? If so, why are you expecting clicks?
May 08, 2012 | 1993 Jeep Grand Cherokee
My 2006 buick lacrosse wont start radio and lights work but its not saying nothing when i try to crank it
Hello! Do you hear a click when the key is turned?...If no click is heard either the ignition key, the Crank relay, the starter, or the battery are suspect...Having lights and radio does not mean the battery is capable of running a starter motor......Put a meter on the battery...should read 12.5 volts...Turn key...Does voltage drop to 8 or 9 volts? Bad battery...If all is well with battery and connections to it...Check the starter fuse # 33 in the under hood fuse/relay box...If the fuse is good that click you should hear is from the Crank Relay in that box...If all of the above is OK connect your meter to the Purple wire that is connected to the starter motor...When the key is turned 12 volts must be on that wire...If there is the starter motor is defective...So, #1...Do you hear a click when key is turned...That would point at a bad starter or weak battery...#2...If you do not hear a click bad fuse #33, bad Crank Relay, bad ignition switch...#3...If fuse is good Bad Crank Relay or Ignition switch; Crank Relay is a low cost item ($10)...Replace Relay...Stop there and send a comment as to results...Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
May 06, 2012 | 2006 Buick LaCrosse
98 Corolla will not start. Turn the key and I hear one click from the lower front of the engine. Not a series of clicks but one click. Is it the solenoid?
sounds like your starter has given all it got, and yea it is under intake manifold between engine and firewall. something to take in countn: check battery state of charge, spin engine by hand to make sure nothing is locked. this litlle engines like to burn oil and see so many run out off oil and engine locks. good luck
Mar 05, 2011 | 1998 Toyota Corolla
I turn the key and get all battery power to sterio and everything but when i turn the key to start it nothing happens the engine doesnt even try to turn over... would i need to just get a new starter or...
If you hear a click then nothing happens then 1- Either the battery is weak. Stereo doesn't need a lot of current. You can turn on the head light and horn at the same time so see if your battery could deliver all current needed to justify the battery. 2- Or your starter solenoid is bad, its poor contacts inside could not carry enough current to the starter to turn over. If you hear nothing, everything is quite then there is a problem with the safety switch at your transmission shifter. This switch is to recognize the Park position before enabling a circuitry to the solenoid starter.
Nov 22, 2009 | 1998 Volkswagen Jetta
When you turn the key you hear a click, click click and then nothing
The click, click, click you are hearing when you turn your key is the starter solinoid attempting to engauge but because the battery is dead it will not engauge. Charge the battery then start the car and check the voltage to the battery. It should be between 13.5 vdc and 14.5 vdc. If it is not, the alternator is bad. If the voltage is between the above mentioned values and the battery goes dead again it is a bad battery.
Nov 16, 2009 | 2001 Hyundai Sonata
My 95 Honda Passport won't start
If you don't hear a click when you turn key to Start, check that the small wire onto the starter solenoid has a good connection. If you do hear the click, check that the large wire going between solenoid and battery has good connections..hope this helps.
Sep 08, 2009 | 1995 Honda Passport
The battery is new. 93 4runner. Turn Key, everything works, turn the key to start, hear the click and then nothing. No clock, no lights, on horn, nothing, as if the battery were disconnected. Jiggle wire...
Check the tremianls on the battery. also follow your ground cable to where it is attached to the frame, motor or body. if the cables are in good shape, cut off the old terminals and replace them with new ones from the parts store. They are only a couple of dollars each.
Aug 15, 2009 | 1993 Toyota 4Runner
Turn key and wont start 05 2500 silverado
This sounds like a weak battery or corrosion on the battery cable connections. The sound you hear is the relay and not the cylinoid.
Jan 13, 2009 | 2005 Chevrolet Silverado
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
