Get my forgotten password
Remote works as does the panel control
    Top Expert:
  • Televison & ... Master
  • 75,314 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Posted on Nov 14, 2014
Forgotten parental control password
Try returning to the initial setup routine and resetting or disabling the pc password
May 31, 2013 | Viore 1111010006 Main Board for LC13VH54...
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Parental controls password forgotten
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password.
Sep 22, 2012 | Proscan 42LA45H 42 in. LCD TV
The front panel is locked and I don't have a remote, what should i do?
Hello
Front panel lock cannot be opened without remote control. If parential control password have been forgotten it can be rectified. If you haven.t its orginal remote call the factory service center and they can get you a new one.
If you need to replace your remote, call 1-800-338-0376. A shipping and handling fee will be charged upon
ordering, and the appropriate sales tax. Have your Visa, MasterCard or Discover Card ready. Your remote part
number is R130A1.
OK.
Feb 13, 2011 | RCA TruFlat 27F520T 27" TV
I've been away on business for the last month and have forgotten my code to unblock selected channels from my kids. how do I rest the tv?
This is from the manual of your tv.
If you ever forget your password,
key in '7', '7', '7', '7' on
the remote control. Then, the
password reset to '7', '7', '7',
'7'.
Good luck
Nov 22, 2010 | LG 42PC3D 42 in. Plasma Television
How do I over ride the password setting
Hello
I thinks that you have forgotten the password. There is a way to reset it.
[1] Make sure the your TV is on standby condition. That is make it standby with the help of remote handset.
[2] Press Volume _ [negative button] on the TVs Front panel and then the "Clear" button on your remote handset for approximately 5 seconds. Keep both of them pressed at the same time during this 5 seconds. The TV will turn back on.
[3] Enter a new password on the next time you access the PARENTAL CONTROL or the TIME menu.
Oct 20, 2010 | RCA 27V530T 27" TV
Forgotten Dell laptop bios password
i'm not sure if this will work at switch on press and hold F11
Jan 18, 2009 | Dell Televison & Video
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
How do you reset forgotten parental control password?
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Oct 23, 2006 | Daewoo DTQ-13P2FC 13" TV
Televison & Video Logo
Top Televison & Video Experts
