Whirlpool washer model wfw9150ww02 just blinks, I looked in the book the blinking is the temp sensor I've replaced it twice now both times it ran one load and quit again
    Problem Solver:
  • 12 Answers
Its shorting out.
Follow the wires and make sure theres a grommet where the wires go threw metal
Posted on Nov 14, 2014
  • 1073 Answers
SOURCE: the washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Posted on Apr 16, 2008
aborcass
  • 2651 Answers
SOURCE: Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Posted on Nov 20, 2008
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
Macmarkus
  • 2605 Answers
SOURCE: my front load whirlpool washer has shut off yet is
Welcome to FixYa.
The "F02" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
The same error as the "F21" on the later model Kenmore/Whirlpool units.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 16, 2010
Testimonial: "I had this problem before. Paid $168.oo to fix! It is so nice to save money and time. Thank you so much!!!"
amomalw5
SOURCE: I have a whirlpool duet
Whirlpool Duet front loading washer- my washer gets mostly thru the cycle,then just stops,and does 3long beeps,repeatedly,until i go over there and hit the power button(but still,all display lights stay on).. the one i have does not have a display,so theres no error code.. but its got water in it when it stops,and ive had to open the washer w/towels at the ready,to get some of the clothes out,to see if thats the problem...but even with nothing in there,the remaining water will not drain out...
Posted on Apr 10, 2012
The hi temp light keeps flashing on my whirlpool dishwasher.
Not sure which particular model you have got. If turning off the mains power off and on is not helping then you will need to reset the controller. "press your "Normal" button then your "Heated Dry" button alternatively several times (quickly). This should reset the control panel and allow you to resume normal functioning."
Read more: http://forum.appliancepartspros.com/dishwasher-repair/11043-control-panel-lights-blinking.html#ixzz2psYY7aFn
Jan 08, 2014 | Whirlpool Dishwashers
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
KDS-R50XBR1 TV red light blinks "2" "two" times
For the KDSR50XBR1, 2 blinks, pause, 2 blinks, etc. means "Temp (temperature) error" and the probable cause location listed is as follows:
- Set temperture is high.
- Temp sensor connector is not attached securely. (CN7020 on HB board, CN7180 on S2 board)
Read more: http://www.agoraquest.com/viewtopic.php?topic=34237&forum=34#ixzz2FYUZCl00
Dec 19, 2012 | Sony KDS-R50XBR1 50" HDTV
Just bought the Whirlpool duet tumbler fresh model # wfw9150ww02. Washer will not start. When I press start the add garment light comes on. Then the door lock comes on. Did trouble shooting as...
Take the back off of the washer...99% of the time it is the wiring that is secured with very tight zip ties. Most of the time it is one of the black wires that has been split in half and is losing contact. Once you have taken the zip ties off fix the wiring and then use electrical tape to join the wire instead of replacing zip ties.
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Ice maker has stopped making ice. Appears no water is getting into the trays. Water is on and water still dispenses out the door, but not in as heavy a stream as it used to. The sensor seems to be...
By your description it sounds like you have ice in the tray but it is just not coming out when you press the lever, if that is the case it looks like you have a common Whirlpool refrigerator problem, the motor is not spinning the auger. You might have to replace the motor module.
Nov 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool washer (model # GHW9200LW, serial #CSM 4604196) is blinking "F02," which means there is a drain problem. My husband disconnected the drain hose and cleaned it. The washer continues to blink...
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Next Step
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Will not run
than either replace heater sensor or element.
Give me model number pls
May 03, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
