Question about Genuine Konica Minolta Konica Bizhub 200/250/350 Developer Unit 4040075200
How can i fix code error c2557
Its saying mulfunction detected
Code C 2556
Posted on Nov 20, 2015
  • Genuine Koni... Master
  • 6,161 Answers
Have you had the developer and drum replaced or does the screen say Replace PC Drum? Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum. YOUR Code deals with the sensor located at the bottom of the image unit. Which monitors the Toner and developer mixture
How do I solve c2557 error ?
Hi
I found your error code and suggested remedies here:
Error Codes Konica Minolta bizhub 250 Code C2557
This site is very useful as by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a pdf format Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 09, 2015 | Konica Minolta bizhub 250 All-In-One Laser...
Code eror bizhub c252
Code: C2557 Code C2557 Description Abnormally low toner density detected Black TCR Sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 5 % or less for a given number of times consecutively. Remedy 1 Perform image troubleshooting procedure if image density is low. 2 Clean the TCR Sensor window on the underside of the Imaging Unit if dirty 3 M7 operation check PWB-M CNDM3-10 to 13 C-21 4 Reinstall Imaging Unit. 5 Change Imaging Unit /K. 6 Change PWB-M. 7 Change PWB-MFP.
Feb 01, 2015 | Office Equipment & Supplies
Bizhub 283 error code c2557
Abnormally low toner detected TCR sensor.
Problem with the developer, toner sensor, or if a PM was done and the counters were not cleared property. Open and close front door to reset. If error returns, check developer unit.
Apr 26, 2014 | Office Equipment & Supplies
Error code 2557
C2557: Abnormally low toner density detected black TCR sensor.
Detailed Error code explained below.
Possiable solutions.
* Open and close the front toner door.
* Restart the machine by turning off the LCD screen power switch, then by the main body switch located behind the access panel above tray 1 indicator light.
* Call Konica to get a tech out.
C2557 Abnormally low toner
TCR sensor
• When sampling data is determined in TC
ratio calculation control, TCR sensor output
is higher than a predetermined value for a
predetermined number of times in a row
even though there is toner in the sub hopper.
Feb 19, 2014 | Konica Minolta Bizhub C550
Error C2557
ATDC sensor error code.You must need replaced a developer.Before replacing reset the special parts counter(I/U life,developer)
Dec 01, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Errorc2557
It is my pleasure to guide you.
Konica Minolta 250 Error C2557 is Toner Density sensor problem
Problem: code C2557 - Abnormally low toner density detected Black TCR Sensor
Sounds like something a technician should take care of. Most of the information I could obtain says that the
Solution: Replaced 4038-R729-00 Hopper Drive Assy (C250 part compatible with C252 )
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Jun 13, 2011 | Konica Minolta bizhub C250 All-In-One...
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
My Minolta Bizhub-200 prntr. has a C2557 error code. How do I clear it?
moz-screenshot.pngmoz-screenshot-1.pngC2557 - Abnormally toner detected black tcr sensor.
Reinstall image unit black
Reinstall toner cartridge
Change Image unit
Change toner carridge.
Jan 09, 2010 | Konica Minolta Bizhub-200 Minolta Printer
Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Genuine Konica Minolta Konica Bizhub 200/250/350 Developer Unit 4040075200 Logo
Top Genuine Konica Minolta Office Equipment & Supplies Experts
k24674
Are you a Genuine Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
