What is code error e03
Code error E03
    Top Expert:
  • 11,573 Answers
Printers & Copiers
Code error E03
Posted on Aug 13, 2016
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
This error code appears to affect Canon printers and to be fairly general.
Basically E03 means "Paper Output Tray is closed./Paper jam".
Please try the following to resolve the problem.
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed.Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button
If no luck, please check using a flashlight, to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, un-plug the printer power supply.
Next, take a dry cloth or Q-tips and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Holding the printer in both hands (you may need another person to help you) , turn it upside down and shake it for a few seconds to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper.Then try to print again.
If no luck, remove all paper from the machine and then blow out the feed roller and paper tray thoroughly with compressed air three or four times.
Once done plug in back in and insert a single sheet of paper and test the printer.
Cheers
Posted on Nov 14, 2014
E03-51 error on dp 6030
Hello Sir; the error code you indicated is corona wire problem, check the charge & discharge unit the corona wire is broken or not, replace it if it does.
Oct 06, 2012 | Office Equipment & Supplies
Canon pixma mp280 error code E03
the solution is http://archer-pcaldia.blogspot.com/2012/11/error-e03-impresora-canon-mp280.html
Apr 27, 2012 | Canon PIXMA MP180 All-In-One InkJet...
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
Apr 03, 2012 | Canon Office Equipment & Supplies
Getting error code E03-40. What does this mean?
E03-40 - faulty toner density sensor try the following press function the original size then 3..... your screen should display f1 service mode then press 8 then start now you should see f8 ..... now press start and scroll down to option 09 and press start now you wait till machine runs the process... after that you need to switch the machine off wait 1 minute and switch it back on
Jun 04, 2010 | Panasonic Workio DP-3520 Copier
Dp 4520 error code E03-60
error e03-60 means waste toner collection. could be a problem with the mechanism that delivers the toner to the waste bottle. looks arround there
Oct 09, 2008 | Panasonic Workio DP-4530 Copier
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
201 people viewed this question
jasbo
jasbo
