I have a Samsung AV Receiver System HW-C700B and Hargray URSU-9000L-HQ remote control and the currant codes does not work. How do I get the correct codes?
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: my bose pmcii lcd remote control does not receive a signal from a bose lifestyle 48 receiver
Have you tried using the remote antenna supplied with the Bose system? This connects to the "Remote antenna" socket on the rear of the media centre and is made up of 2 parts: a shielded section (black in colour) that runs past any sources of interference - mains or signal cables, other electronics products - and the unshielded antenna (clear plastic covered copper wire) that must be fully extended vertically to act as an aerial. Position this away from sources of interference and as close to the second room as possible (Bose do a longer version, free of charge in some countries....)
The remotes only have a range of up to 20metres - this will drop the more walls it passes through and the thicker the walls. Any interference can affect this - radio transmitting equipment (WiFi, video sender, but especially products transmitting on the same frequency - 27MHz or 40MHz, e.g wirless thermostats or alarm systems....) or products with poorly shielded transformers. Experiment with swtiching off other electical equipment (including lights if they have a transformer - e.g. halogen spot lamps). If you identify a source, can you move it away.....?
SOURCE: setting remote to control stereo receiver.
Switch stereo on and try one of these codes at a time. didn't know if it wasa 3 or 4 digit code you needed so i listed them all. If the none of these work try putting a zero in front of all the 3 digit codes. ie. 0626, 0706 etc.
hope it works.
Hughie.
0706, 0806, 0858, 0859, 0681 0689
626, 706, 726, 806, 858, 859, 601, 609, 618, 681, 689, 698,, 859
SOURCE: Want to set Times Warner Remote for Samsunf DVD-VR320 Combo
the code for mine was 170 but there are easy instructions to figure it out here
http://www.timewarnercable.com/MediaLibrary/1/1/FAQ/Remotes/CLIKR5_UR5L-8700L.pdf
the auto-search is how i did it.
SOURCE: Remote control not recognizing codes
Codes for many of our TVs can be found at InsigniaProducts.com. For the Blu-ray player, we recommend using your universal remote's scan or learning feature.
SOURCE: Need receiver code for Bell 6131 receiver, trying
try with the code 00775, it works fine with my sony nx810 remote
