Question about Water Heaters
Mr innes 10 clydesdale ave paisley pa34jl homecare number910004379796 cancell account got one lot cheaper
IT doesn't heat up any more so the towel does not get warm, do you know anything about towel warmers? do they have an element?
Many do have an electric heating element; there may be a light next to the switch which might indicate whether it is on or off. However some are heated by hot water or steam (it seems). You might consider changing the element, try the fuse in the circuit first, it might save you a lot of trouble. If you decide that are able to change the element yourself, get the instructions and only then source the part. If it's wall mounted it's more difficult. However it's probably best to get an electrician to do it as it can be very tricky. I may even be necessary to contact the manufacturer or buy a whole new item
I hope someone else comes up with a better answer !
19.January.2016
Jan 19, 2016 | Mr Steam W542 Heated Towel Warmer W542...
How to wire for 220 volts/
you got me there I have wired lots of water heaters and none had a motor nor 10 wires
Jun 14, 2015 | Water Heaters
How do I properly create Google account on my s4
It will usually walk you threw setting up a google account when you go thru set up.. Otherwise, you can set one up at google: Create your Google Account After you have set up account on computer, go to settings on your phone, then accounts, then add a google account.
Dec 28, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Sw10de water heater electric side quit heating
check for damaged fuse block or connection on it. pulls a lot of current
its in your fuse panel.
meaning you have to remove panel an pull it out an check it an the wiring .
youll put your eye out.
Aug 03, 2014 | Suburban SW10DE 10 Gallon Water Heater
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
Can I install 4500 wt elements in a marathon MR50238? The tank specs are the same as MR 50245.
1) Product warranty will be voided if you install 4500 watt elements in year-2008 model MR50238 3800 watt marathon tank.
Older 3800 watt element models have been discontinued.
2) Copy following links for Marathon resources:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Product warranty is voided if element wattage exceeds label on side of unit.
4) Marathon has a problem with elements burning out frequently.
To solve this problem, they suggest installing element with lower wattage, such as the 3800 watt.
Upper 3800 SP610130
Lower 3800 SP210197
Feb 20, 2013 | Water Heaters
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
Have an atwood 10 gal water heater that leaks but I can't find the leak. The lines are dry. Have a lot of water in interior under the bathroom tile.
Also open cover and check if element is leaking. Elements frequently leak at rubber seal.
Next suspect is rusted-out tank that is leaking through a thin-place in the tank.
Otherwise there are not many other places to check if pipes are dry, especially with the Atwood 10 gallon.
I suggest replacement.
http://waterheatertimer.org/Water-heater-is-leaking.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | RTO Atwood Water Heater - 6 Gal LP
My pilot light won't stay lit, I thought it was a down draft but a friend said it might be the regulator. Do you think that also and can I fix it my self?
Try replacing the thermocouple.A lot cheaper & easier.The pilot flame burns it at the burner.Downdraft isa very rare problem.
Jan 05, 2011 | Reliance Natural Gas Water Heater Control
Water heater working fine but very little hot water coming out
alot of time those small units do not have a fast recovery rate so if they are on for a min or more they might start to lose temperature. if it's on demand especially in cooler climates it might not have enough power to heat it up and keep up with your demand
Jul 29, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heaters Logo
43 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
