Question about Dual Invision Dvd System Headrests 09 Lincoln Navigator
How do i fix an eject problem with my invision headrest dvd player.
Main unit plays but will not eject disk
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
Burning movies on the computer , playback fine on two computeers , will not play on ONN portable player used DVD-R
Burning dvd\'s is always a crapshoot when you have multiple machines. Computer drives are more tolerant on playback - the problem lies with your other, independent playback units. That is why in your main viewing area it is important that you have a few units so that if disk does not play in one machine, it will play on another. Has to do with the individual differences and calibrations of the machines involved. Store bought dvd\'s have less problems because their laser reflectivity is always higher than disks you burn, and therefore, easier to read properly. Price of the unit has no reflection on ability to properly read the disk. Sometimes and often, a cheaper machine will work better with copies - you never know.
Feb 19, 2014 | Computers & Internet
What company make cbx-3010t
CBX-3010t is the controller module for the in-headrest DVD systems made for Invision Industories:
http://www.invisionautomotive.com/default.aspx
It is used in the Revolution (Rev) 3 series where there are four headrest players, the front two being DVD players and the back two are satellite units feeding off of the front two.
As for the actual company that manufactures the controller I don't know.
May 27, 2010 | Toyota Car Audio & Video
Headrest built-in DVd with disc stuck...help
Look for a small hole under or on the side door assembly, if found use a paper clip or other thin metal straight object and insert into hole this will release the disc clamper and open the door.
Nov 25, 2009 | Televison & Video
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
DVD will not play a disc, when you close the tray, it will eject
Bad Disc.
Try a known good store bought Movie in player?
Still Bad Disc?
DVD unit in your player is bad.
Throw in garbage.
Feb 19, 2009 | RCA DRC8320 DVD Recorder/VCR
W200 will not play any type disk say "disk error"
The only fix i've found for this (without replacing parts) is to turn the unit off and back on and it will read the cd.
Aug 20, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
My car dvd player wont eject dvd's or take them for that matter.
Sound like yor unit load/eject mechanism is bad, take it to a local shop if it fixable then it would cost around $100. Call me I know e few dependable shop. 801-414-4566.
Feb 06, 2008 | TMI Products Vizualogic Headrest Pair...
Video output not working
it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
Feb 25, 2007 | Kenwood DDX-6019 Car DVD Player
Dual Invision Dvd System Headrests 09 Lincoln Navigator Logo
77 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
