Question about Ovens
Beko bsc630w tripped electric when turned back on oven made an electrical cracking sound and I could smell burning
  • Ovens Master
  • 2,540 Answers
Do not use this oven as you could have a bad fire. Sounds like a dead short You need a repair man who knows about these things.
Posted on Nov 15, 2014
imadejoolaff
  • 27 Answers
SOURCE: Electrical fault on SE250Xuk
It may be something as simple as a crossed or frayed wire. This does not necessarily mean major repairs. Since it is electric, UNPLUG the oven from the wall. Then, take the burner rings out and lift the stove top. You should be able to lift it from the front edge, since it is hinged at the back.
Check the wires under the burner. If these wires are in good shape and the connections are solid, move the stove out from the wall. Remove the back sheet metal panel completely.
Once again, check the wires running the entire length. Make sure all wires running from the knob console to the rest of the oven are not frayed or missing the insulation coating and that the connections are complete and not loose.
If you find frays, some electrical tape should fix it just fine. Loose connections can usually be crimped with a pliers, or if it's a loose electrical connector type connection with a screw, you can remove the connector head and wrap bare wire around the screw, then tighten it down to secure.
If you find nothing wrong when you open it and inspect the wires, then it is possible it needs major repairs. If you are getting a burning smell from ANY electrical appliance, please leave it unplugged until you get it fixed. Nobody likes a house fire in the middle of the night.
Posted on Mar 03, 2009
localwonder
  • 6784 Answers
SOURCE: Oven won't heat up
Ok, this is a definite element malfunction. you can confirm this by using a multimeter and connecting the meter to the terminal points on the element. once connected, turn on the heating cycle and if you can register a reading and the element dosen't light or produce any heat, this will confirm element failure and you will need to replace it.
Please rate and god bless:)
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
Posted on Sep 17, 2010
repairman45
  • 130 Answers
SOURCE: a couple of days ago when using the oven I smelled
Yes, the problem you are describing is most likely a fried heating element. This can be repaired for around $40
Posted on Dec 01, 2010
  • 52 Answers
SOURCE: During self-cleaning cycle we heard
If any appliance trippes the breaker there is a problem that has to be looked into, no appliance should trip MCBs or RCBs (trips), ISOLATE THE MAINS POWER BEFORE REMOVING ANY PANELS
A visual inspection of the rear is required, also the electrical mains connections. Look into this do not use the appliance until you have resolved the problem, it may turn out an amount of food had been stuck beside one of the heating elements, and causing a smell, better to be safe.
Let me know if you require any further assistance.
John
Posted on May 20, 2011
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
My electric Oven keeps tripping the breaker off as well as making a popping noise while doing it and leaving a burning smell. When i turn the knobs to the burner on i hear a clicking noise coming from the...
Hi. YES you most definately have a short. The burning smell is coming from either the wire arcing and thus producing ozone and heat, or the insulation on the wire is being burnt. Take the back off the control unit to expose the wires and see if you can see where the wiring is burnt. It could be a loose connection, or something more serious.
If in doubt, call a professional repairman to check it out.
Earl Marshall
Norse Tool/Equipment Repairs
Sep 22, 2011 | GE JKP15 Electric Single Oven
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
May 16, 2010 | Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
Jan 14, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Ovens Logo
59 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
