Question about Jacuzzi Hot Tubs & Sundance Equalizer: Stereo Crossover Speaker Module 20198-001
My jacuzzi hot tub is flashing f1 code I read where to reset it press the +and- at the same time then adjust it with the warmer or cooler buttons to F0 thru F6 where should it be set at?
I had a jacuzzi dealer want to replace the circulation pump? for over 400$ I replaced the filter even tho I had drained and filled and bought new filters this summer, he is rude and over priced and no one else in the area. I bought new filters (the same as he sells) on line for less money. So now the f1 is still flashing?
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Dream Maker Hot tub - Display is blank - no #'s - flashes 4 times
Hard to say without being there. Two things to check though. First be sure the new board is the correct one. Many times parts will change and replacements will have special instructions for retrofitting.
The other thing to check is be very sure the plug on the new board lines up with the receptor. On a multi pin plug if the pins don't line up you can get just the problem you describe. I hope this helps, sorry it can't be more.
Feb 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Jacuzzi hottub flashes f1 code. Tried hose in heating element and new filter.
The F1 code on my Jacuzzi is just the setting for the filteration mode. If you press the + and the - sign at the same time than release. Then press the warmer + or cooler - to select filter mode F0 thru F6. If you are getting a FL1 code means the flow switch is malfunctioning.
May 05, 2009 | Jacuzzi Home
Jacuzzi Hot Tubs & Sundance Equalizer: Stereo Crossover Speaker Module 20198-001 Logo
153 people viewed this question
Top Jacuzzi Hot Tubs & Sundance Car Audio & Video Experts
xxxxxx xxx
Are you a Jacuzzi Hot Tubs & Sundance Car Audio and Video Expert? Answer questions, earn points and help others
