Get out of malfunction mode?
Stuck in malfunction. cannot operate or change settings other than turning off. thank you
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 179 Answers
Most likely there is a problem that will need a dealer to fix. Stuck in Malfunction Mode means there is a problem.
Posted on Nov 14, 2014
Testimonial: "thank you"
Can't change what vents A/C and heat blow out of.
While it's possible there are other problems the repair procedure would be to replace the blend door motor and while doing so confirm that the blend door moves freely without binding up.
Aug 04, 2016 | 1999 Chrysler 300M
It seems to be stuck in 4x4 an bindsup when making acompleat turn
The binding up is normal for 4x4 mode because the parts which normally are bypassed in a 2 wheel mode are locked and rigid in a 4x4 mode. But being stuck in 4x4 mode is not normal.
Some of the units are Vacuum operated, others are electric. The electric units use a single solenoid with a variable length
plunger that gets its signal from the dash knob. When the lightbulb in the dash selector knob burns out; the voltage changes at the solenoid plunger. The plunger then operates differently than how it is set on the knob selector.
For the electric models, you would put a voltmeter on the wire to the 4x4 shift solenoid and have someone move the selector knob to each position and see if the voltage changes.
Oct 05, 2013 | 2001 Mercury Mountaineer
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
I have a motorola v3..it worked well for the past years.but suddenly whenever i compose a text message my phone starts to hang up and its stuck... i tried to shot it down and turn it on once again...it...
The phone stuck due to this instances
Phone memory is low that's why its getting stuck,it means,not enough memory may cause malfunction.
Solution are :
* delete unused data or files so there will be a free space on your phone memory and to be able to operate smoothly.
* Reset the phone by this procedure,go to settings > initial set-up > Master Reset or Master Clear
Master Reset - your phone settings will go back to default (no data will be deleted)
Master Clear - your phone setting will fully format. (all data of yours will be deleted) and back to original settings.
before doing master clear,be sure all of your important data must be saved before doing this method.
I hope this solution will help you. thank you for visiting fixya.
Jun 17, 2011 | Motorola Mobility RAZR V3
Display says it is stuck on dvd 2 cannot program the dvd recorder to record
DVD recorder stuck on DVD 2 mode that means you can no longer operate it with its remote, right?
Now you need to change remote mode to DVD 2 so recorder can receive its signals.
Slide down lower cover of remote and set Command Mode switch to DVD 2 position, now your recorder will get remote signals and you can operate it properly.
Thanks.
Jan 18, 2011 | Sony RDR-VX521 DVD Recorder/VCR
My laptop monitor is stuck in full screen mode after a game malfunctioned and the computer shut down. I did a system restore but it didn't change. Operating system - Vista.
Firstly, uninstall the game. then reboot the PC in safe mode. Right click on the desk top and select properties. Then select settings. From here give new settings to your monitor. If this does not wirk then Control Panel->System->HardWare->Deivce Manager. Select Display Adapters. Uninstall it and reinstall.
Aug 19, 2009 | Computers & Internet
Monitor stuck in standby/hibernation mode
Since you havent mentioned the operating system u are using .You can change the standby time manually to which you want .
As of now turn on ur machine and change the settings .There will be no need to enter bios settings
Jun 03, 2009 | Dell Dimension 8400 PC Desktop
Need help disabling Toshiba 3550 sorter
I don't have operational sorter, but I can locate one for you if you are interested. Now, the solution to you copier is for you to go into the service mode and change the setting from sort to non-sort. This is the step you need to take. Go to the Service mode by doing the following.
1. Turn of copier
2. Push on 08 then Power on copier
3. enter 4 then
4. Push Print
5. Change the current value from 1or 2 to become 0
6. Push or press Interupt to reprogram the copier.
7. Then enter 09 to get out of the service mode.
Good luck.
Mar 23, 2009 | Toshiba Office Equipment & Supplies
Can this camera be RESET? Camera Stuck in Clock set mode.
If you are familiar with camera repair then apart camera and check navigation switch board is intact with main board of camera.
That is only reason of switches no operation in this camera.
Feb 03, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
