Question about Jacuzzi Hot Tubs & Sundance Equalizer: Stereo Crossover Speaker Module 20198-001
What does the filtration number need to be set on for jacuzzi hot tubs? example f6? compared to f1?
I Have the f1 flashing, I read to reset it by holding the + and- at the same time then adjust it to f0 to f6 .... what one do I set it on?
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Why is hot tub over-heating past max temperature?
Sounds like a problem with the thermostat.
Aug 05, 2014 | Jacuzzi Home
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Jacuzzi hottub flashes f1 code. Tried hose in heating element and new filter.
The F1 code on my Jacuzzi is just the setting for the filteration mode. If you press the + and the - sign at the same time than release. Then press the warmer + or cooler - to select filter mode F0 thru F6. If you are getting a FL1 code means the flow switch is malfunctioning.
May 05, 2009 | Jacuzzi Home
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
http://hottub.synthasite.com
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Jacuzzi Hot Tubs & Sundance Equalizer: Stereo Crossover Speaker Module 20198-001 Logo
141 people viewed this question
Top Jacuzzi Hot Tubs & Sundance Car Audio & Video Experts
xxxxxx xxx
Are you a Jacuzzi Hot Tubs & Sundance Car Audio and Video Expert? Answer questions, earn points and help others
