Question about RytherCamera Sony NEX-EA50UH Camcorder with 18-200mm Servo Zoom Lens"
I have NEX-EA50 camera and has lens error 61:30, is any solution witch i can fix it at home myself?
Is nay solution that i can fix this error 61:30 at home my self?
I want to repair nikon coolpix l30 by myself at home when it shows lens error what should i do
Try
http://camerarepair.blogspot.co.uk/2007/12/fixing-lens-error-on-digital-camera.html
Jul 23, 2017 | Nikon Cameras
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
HOW TO PUT Fotodiox 49mm Filter Thread Macro Reverse Mount Adapter Ring for Sony E-series
The ring threads onto the front of any lens with a 49mm filter thread, just like a filter. The front of the lens then fits onto a camera body, effectively mounting the lens "backwards" or reversed. With most lenses, this allows the lens to focus very close, for close-up or "macro" photography.
Mar 14, 2013 | Fotodiox 49mm Filter Thread Macro Reverse...
Sony camera sea water damage and wet
Highly unlikely that it can be repaired, salt water caused corrosion and will short out electronic components when the battery is connected.
I suggest you put your money towards a new camera.
Oct 20, 2012 | Sony Alpha NEX-5 Digital Camera with...
Yashica Lens 28 - 80 mm can i fix any digital camara
With the proper adapter, Contax-mount lenses may be used on several different makers' digital cameras, including Canon and Sony.
Oct 01, 2012 | Kyocera Yashica Lens Mc Zoom 28-80mm...
I am getting 'camera error" after using the nex 3
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 19, 2011 | Sony NEX3 Digital Camera
Lens error 12, And lens error 22. I want to know what those are and how to fix it...can I fix it myself or do I have to take it somewhere?
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 27, 2008 | HP Photosmart M420 Digital Camera
RytherCamera Sony NEX-EA50UH Camcorder with 18-200mm Servo Zoom Lens" Logo
41 people viewed this question
Top RytherCamera Video Cameras Experts
Are you a RytherCamera Video Camera Expert? Answer questions, earn points and help others
