Question about Dryers
I have the heater 2 years and I now hear a noise and the front bottom is getting extremely hot right above the blower vent.
I am afraid of a fire starting. What can I do. Can this be replaced?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 179 Answers
Make sure the blower vent passageway is clean and free of debris. It should like the vent is plugged.
Posted on Nov 14, 2014
watugot
  • 290 Answers
SOURCE: dryer too hot
You will want to make sure the lint screen and vent are free and clear.
If the dryer is blowing out the vent outside the house as it should, then you have a thermostat problem.
If the operating thermostat does not open properly then the element will cycle by the hi-limit thermostat which will cause the dryer to heat more than normal.
Posted on Nov 24, 2007
rickzilla
  • 706 Answers
SOURCE: Maytag Performa dryer venting
You are always better off using steel on these kinds of conversions and do not worry about how hot it gets,..Aluminum will get hot too. Steel is more rigid and less likely to dimple in while installing or hooking up the external vent system... Hope this helps..
Posted on Sep 01, 2008
  • 66 Answers
SOURCE: Dryer takes a long time to dry.
This sounds like the vent is plugged up. The dryer gets rid of moisture through the dryer vent and hose. When this gets plugged up it will take a long time to dry or the hi limit will shut it off. When the dryer vent or hose is partialy blocked it will take vary tong times to dry the clothes and will eventualy cause the dryer to stop drying all together.
Posted on Nov 14, 2008
  • 181 Answers
SOURCE: back of dryer gets extremly hot!!!
put hand at the outlet to see if the warm air is freely coming out. if not there could be a blockage in a pipe inside or the propler fan on the motor has failed.
Posted on May 13, 2009
canbruce75
  • 1776 Answers
SOURCE: Same model - same problem
Check for a faulty high limit thermostat. It is a small round black device mounted on a metal plate. It is usually mounted to the internal ductwork with two screws. It can be tested for continuity using a multimeter or ohm meter. It should have no continuity. If it has continuity, it is stuck open and is faulty. I am attaching a pic showing a thermal fuse and high limit thermostat for reference. Hope this helps and best wishes.
Posted on Aug 18, 2009
I have a 1999 jeep grand Cherokee limited edition my heater only throws out cold air why is that?
this is easy. (are you moving or parked) ill assume stopped.
first is the blower working, (seems so)
ill guess that no heat in all vent modes, and re-circ, on.
next is the engine fully hot, hot means at 180F or more holding
(we measure it with a pyro gun)
next, are both heater core hoses hot/ at the fire wall? and equal at 180f?
yes, good. then the damper is stuck closed i the heater box.
no , then there is heater core blockage. (skipping every 2 year flushes are you, sure...)
it only takes 2 things
hot water ,p[assing through the heater core
and air passing through its fins to get hot cab air.
just 2.
Nov 14, 2014 | 1999 Jeep Grand Cherokee
No heat when vehicle hits running temp
NO year Wangler makes this hard..... no year, no joy. sorry/
engine at 180F and holding, that is step 1
step 2 is, the blower fan runs on high, at full speed
yes/no?
and last , if the heater core is hot (feel it)
then the dampers are wrong.
on my 08 i feel the 2 hoses on the core as they pass through
the fire wall, are they roasting hot (180F)
then if air passes through the core,said air must get hot.
if you feel nothing at vents, in all modes, the main TEMP. damper
is stuck closed, (this is the red and blue knobs)
the 10steps that work on any car, they all have a heat exchanger.
http://www.fixkick.com/AirCond/heater.html
Feb 10, 2014 | Jeep Wrangler Cars & Trucks
My front heater is throwing very little heat the back is throwing more heat could hear the back blower but not the front
If you cant hear the blower on the front side, its probably gone out. If you can hear the blower and theres cold air coming out the vent, its the flap that switches from hot to cold thats not working
Jan 08, 2014 | 2005 GMC Envoy Xl
No air/heat coming through vents
u more then likely have a bad blower motor resistor
Jun 20, 2013 | 2000 Chevrolet Blazer
My 2005 Ford Expedition is blowing hot air from the front vents and suddenly the rear vents stopped working at all but I can sometimes hear a noise on the rear part of the truck ,may someone please tell me...
to me this sounds like a blend door problem. this is in the heater box, first you need to pinpoint the noise. there is 2 heater boxes on front and a rear both have blend doors. being you hear a noise, I suspect either door is jambed by forign object or broken, but still could be a problem with the actuator for the door. as for the rear not blowing?,check the position of the front blower switch, one position will disable rear function. honestly this
should be done by an experianced technican, I was 20yrs ford.
Apr 02, 2012 | 2005 Ford Expedition
The front heaters are not blowing out any air, but the back heaters blow out air, but it's not very warm, and my passenger side front tire makes a rubbing noise when I turn to the left.
you have to check to see if you have any power at the blower motor, if you do then the motor is no good, if you dont you could have a bad blower motor resister. If its not blowing that hot you might have to flush the cooling system.
The noise you hear when you turn is probably the right front hub bearing
Feb 05, 2011 | 1998 Ford Explorer
My heater coil went bad,and i recently bought a new heater coil and it was placed in the truck-1994 chevy blazer s10 4 door,vortex engine,the problem is now,that the blower is not working or the fan,and no...
I ASSUME you replaced the heater CORE? You need to find the ticking noise in front, just turn key on, turn blower on, and find out where its coming from. It cant catch fire, not from that anyhow. The radiator releases the heat from the engine, you are using a fraction of that heat for the cab of the truck. Rap on the blower motor and see if it starts to run, if so, replace it. Check the fuse.
Dec 06, 2010 | 1994 Chevrolet S-10 Blazer
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Dryers Logo
52 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
