Question about Hardware & Accessories
I need maual 27133
The timer seems to be working, but the water is no longer comeing thru the sprinklers.
Nelson water timer instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Link has all sprinkler timer manuals available online 2012.
Probably does not include older timers since manufacturers post recent manuals, with expectation that today's sprinkler timers do not last long. Except for Intermatic 120V-240V sprinkler timers that are made to last decades and have replacement parts.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment as needed.
Jun 06, 2013 | Hardware & Accessories
Raindrip water timer instructions
Copy following link for links to all sprinkler timer manuals, including raindrip:
Sprinkler timers generally have 1 year limited warranty.
Always reset digital timers to help restore functionality.
Simple power outage can cause digital timers to malfunction, or fail.
Add surge protection to timer circuit.
May 31, 2013 | Hardware & Accessories
Yardworks timer 59-3213-8 not functioning properly
Yardworks is a non-supported brand name that re-packages timers from different manufacturers including Orbit, Melnor, Tork etc.
Copy following link to access sprinkler timer manuals, to help identify product.
Most Yardwork timers are sprinkler, but I have also seen auto-off christmas light timers.
Add a comment and describe timer in detail. Otherwise the only google result for that timer model is fixya, which indicates there are no online resources.
Also check battery ... if timer has battery, it will last about 3 years.
Also do not expose water timers to freezing temperatures.
Most timers last a couple years, and most have 1 year limited warranty against defects in workmanship. Unknown who supplies warranty coverage for Yardworks.
May 03, 2013 | Hardware & Accessories
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
Sep 10, 2012 | Hardware & Accessories
Need instruction manual for Orbit model 27133 sprinkler timer
Pretty sure this is what you're looking for:
http://www.orbitonline.com/lib/media/27133-24%20rA%20%284%291.pdf
Jul 29, 2011 | Orbit 2-Dial Hose Faucet Control Timer...
The timer no longer plays all 3 programmed zones. It play only one.
Three things to look for:
1) If sprinkler turns on-off but doesn't advance to next zone, then Sprinkler Valve is suspect, and timer is good.
2) If sprinkler stays on all the time, or never turns on, then Timer is suspect.
3) If sprinkler turns on-off, but leaks when it's supposed to be off, then Sprinkler Valve is suspect, and timer is good.
Jun 24, 2011 | Intermatic T8845PV - Sprinkler-Irrigation...
Automatic sprinklers (Intermatic timer) do not work in automatic, but manual does work. When I cycle the timer, the solenoid activates but not enough for the sprinklers to spray. Manual works fine. Any...
If manual override works, and dial rotates on time each 24-hours, then worn trippers are suspect.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Intermatic R8806P101C -...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
Hardware & Accessories Logo
104 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
