Question about Lavazza Espresso Point Capsule Machine
My lavazza espresso point machine leaks water into the tray. where can I get the seals kit to repair it?
Leaks water into the tray when making coffee
SOURCE: cold espresso
it may be the the back fuses not working or the two thermostat are not working good, or the worst possibility can be the electronic card.
Posted on Apr 29, 2009
  • 19 Answers
SOURCE: I do not have a manual for our Lavazza Espresso
contact me at www.lavazzzarepair.com
Posted on Oct 13, 2009
  • 19 Answers
SOURCE: My Lavazza Espresso Point Capsule Machine dispenser dry!
Sounds like you need a pump contact me www.lavazzarepair.com
Posted on Nov 12, 2009
tbreeze47
  • 3083 Answers
SOURCE: lavazza espresso point (one month
You should take it back and get an exchange, refund, or a different make. It could be something as simple as a loose water hose, but it's going to take disassembling the machine to find and fix it. Your best venue is to get a different one- this one is seriously flawed.
Good luck, and hope this helps.
Posted on Aug 24, 2010
wentlanv
  • 710 Answers
SOURCE: I have the Lavazza point.
I owe this solution to one of our experts, Seldemseen: "there is a O-ring seal between the heater and water feed...U have to remove apprx 8 allen screws on the top of the heater plate, remove the wiring connectors from the heating element and overload sensors and the heater plate romoves from the attached bottom plate. The seal is located on the center nipple and is apprx 1/8" round."
He replaced his seal with one from his local hardware store.
Good luck to you,
I hope this helps. If it did, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 25, 2011
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
Water leaks from the top of the right side of commercial coffee maker
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
Short pot of coffee
Aloha, ukeboy57
PS, Check the pots in the office. Make sure they are all the same size. Decanters come in 3 sizes; 10 cup, 12 cup (standard), and 3L (3 litters). Check the decanter brand as each brand is a bit different in size. All metal decanters are usually very small (8 cup). What ever size you use, just make sure they are all the same.
Mar 09, 2014 | Bunn VPR Coffee Maker
Leaks water
the tray you pour the water into sits directly on the tank that heats the water with a gasket between tray and tank, this gasket has worn away, Bunn no longer sends replacement gasket, I made one myself
Feb 25, 2013 | Bunn 10 Cup Home Coffee Brewer
Water leaking under the machine
Take a look at the little spout area that pours into the water tray. It can get clogged with coffee grounds. This was our solution with one machine. But with another, the water was actually leaking out the back and was the result of a dying boiler assembly.
Dec 12, 2012 | Saeco Vienna Plus Espresso Machine
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Lavazza Espresso Point Capsule Machine Logo
537 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
