Modify my printer in the automatic manner - Office Equipment & Supplies
What is an adverb
An adverb most often modifies a verb or a verb phrase. It provides information about the manner, place, time, frequency, certainty, or other things about the verb or verb phrase in the sentence.
Dec 12, 2013 | Franklin LM-6000 Speaking Language Master
My printer only shows "printing", but not print.
Check the print spool setting in Windows Services.
Make sure "Automatic" is selected as default.
In order to go to Windows services:
(1) Right click on MyComputer
(2) Select Manage
(3) Click on "Services and Applications" in the left pane.
(4) Select "Services" from right pane.
(5) Look for your printer name and select it to modify.
Aug 08, 2013 | Office Equipment & Supplies
How do i change the screen from vertical display to horizontal
The IBM ThinkPad Z61t computer runs the Windows operating system. Normally, Windows is displayed on a monitor in a manner that makes it easy to read. If you want to change the screen display configuration (from vertical to horizontal), modify the screen display properties in Windows itself. This process causes the computer to rotate the image displayed on the screen by 90, 180 or 270 degrees, depending on the setting you choose.
1.Right-click on an empty portion of the Windows desktop on the Z61t.
2.Click "Properties."
3.Click "Display."
4.Click "Change display settings."
5.Click the "Orientation" drop-down window. Select the "Landscape" option to make the screen display items in a horizontal manner.
Sep 19, 2011 | Lenovo ThinkPad Z61t Notebook
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
The ink cartridge cannot be recognized ,but the ink cartridge was installed properly .Unfortunately,the ink was flowed out ,please tech me a proper manner to comb this problem as soon as possible
Hi, are you using the original ink cartridge or your ink was modified to CISS before? If you just finished refill your ink and this problem occur - the ink cartridge cannot be recognized, you shall take out both your ink cartridge and try to wipe the whole thing with a clean cloth and then carefully put in back. Hope it helps you. Good luck =)
May 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
What I can do for automatically cleaning?
Printhead cleaning is done automatically each time the printer is turned on, and periodically during printing.
If you are having print quality issues, you can use the cleaning utility located in the drivers folder, the printer properties, under the maintenance tab. Cleaning in this manner should be limited, it uses a lot of ink.
May 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Have a canon pixma mp560 every time I print it says printer paused how do i fix
try these steps:
Setting SNMP on the Device SNMP helps monitor the state of the machine and collects information on it. The following items can be set:
<Community Name>: Sets the SNMP community name. You can specify up to two community names. <Writable SNMP>: Enables the computers on the network to access the machine and modify its settings if this item is activated. You can specify this setting for each community separately. <Get Printer Management Information from Host>: Enables automatically the SNMP port monitoring function to obtain printer management information such as information on print applications and printer ports, if you are using Windows Vista and set [Standard TCP/IP port] for the printer driver port. 1. Press (Additional Functions).
Press g0014901.png (Additional Functions). 2. Press [System Settings] 7400rightpointer.jpg [Network Settings] 7400rightpointer.jpg [SNMP Settings].
If the System Manager ID and System Password have been set, enter the System Manager ID and System Password using g0015291.png - g0015292.png (numeric keys), then press g0015353.png (Log In/Out) to enter the System Settings menu. The SNMP Settings screen appears. 3. Select [On] or [Off] for <Use SNMP>.
[On]: When you set or browse each item of the machine with utility that uses SNMP to obtain information. Proceed to step 4. [Off ]: When you do not use an SNMP utility. Skip to step 7. 4. To change Community Name to a name other than <public>, press [Community Name], then enter the community name using the touch panel keyboard.
5. Select [On] or [Off] for <Writable SNMP>.
[On]: Allows the computers on the network to access the machine and modify its settings. [Off ]: The computers on the network cannot access the machine and modify its settings. 6. Select [On] or [Off] for <Get Printer Management Information from Host>.
[On]: Enables the SNMP port monitoring function to automatically obtain printer management information such as information on print applications and printer ports if you are using Windows Vista and set [Standard TCP/IP port] for the printer driver port. [Off ]: Disables the above function. 7. Confirm the settings you specified, then press Turn off the machine, wait at least 10 seconds, then turn it on. [OK].
8. Press [Done] repeatedly until the Additional Functions screen closes.
9. Restart the machine.
Nov 06, 2010 | Canon imageCLASS MF7480 Laser Printer
Have broken the automatic document feeder top tray and Kodak doesn't sell replacement parts. Kodak informed me to buy a newer model My 5500 works fine. Can you help lead me in the direction to buy a new or...
Find & salvage the tray from a used 5500. I occasionally find items thru ebay, craigs list (by placing a wanted notice), computer repair or recycling centers & even goodwill stores. Alternatively see if the tray can be fixed or modified.
Oct 14, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Microsoft Live Mail desired synchronization can't be maintained.
If you are using Version 2009 (Build 14.0.8064.0206), you should be able to right-click on the folder in the folder pane, select 'Synchronization settings', and select either 'All messages' or 'Headers only' from the list for every folder you wish to modify. Once all of them have been modified to your liking, close Live Mail and reopen it. Your settings should have been saved and should not have reverted to 'All messages.' I have found that if you do not restart the program, it sometimes ignores configuration changes. If you are still using Version 2008 (Build 12.x.xxxx.xxxx), I would recommend visiting http://home.live.com to upgrade to the latest version first.
Feb 02, 2009 | Microsoft Windows XP Home Edition
k24674
jasbo
jasbo
