Question about Ricoh Nashuatec MP2000 Toner 9000 Yield Type 1130D - Genuine OEM toner
My photocopier machine stacks the paper at the last end of ejection point
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
Fuser problem or exit unit. Clean all the rollers in that area w/ alcohol isopropilico or a RAG of soap and hot water(not too much water)
Posted on Dec 11, 2014
What is the reason Drawer 1 feeding two or more papers in photocopier canon 2320L
The separation pad is probably worn out. This pad creates friction against the bottom of the paper stack to stop multi-feeding.
Aug 28, 2016 | Canon Office Equipment & Supplies
Tip
Minimizing Paper Jamming in any printer
When using any laser printer, monochrome or color machine, be sure to fan the paper before inserting into the paper cassette tray. The technique is simple. Holding a stack of paper in your hands, each hand on the short edge, flex the paper to create an arc in the stack. Then pinch down on the ends of the paper and straighten the arc out. You'll produce a bulge in the middle of the stack which creates an air space between every sheet in the stack. Now the paper will not cling and paper jams will not occur.
The 2nd tip is to note which "direction" the paper is cut because feeding the paper in one side first may provide better traction than if you were to feed the other end in first. Paper has a grain and its lays down in one or the other direction.
on Apr 04, 2010 | Office Equipment & Supplies
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Dec 08, 2014 | Copystar CS-2550 All-In-One Printer
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
I have a Sharp Z50 photocopier. When I feed the paper in manually, it prints but gets stuck and will not eject.
Check if theres no particles on the paper path.check the size of paper.check the settings.also check all the feed rollers .check the sensor ,connectors and mechanism.
Dec 22, 2013 | Sharp Z50 - Z88 Toner
SOMETIMES FEEDS UP TWO OR MORE SHEETS WHEN IT SHOULD ONLY BE ONE
many printers have a rubber or cork pad under the feed wheels to hold back all the sheets, except the top one. This one doesn't have that, so we'll try a couple other things.
Pull the tray out and remove all the paper. If you're reusing old paper, that might be your problem. Assuming you have fresh, clean paper, take the whole stack, pinching it at one end, and bow the stack up in the middle. Now pinch the other end of the stack, relax the grip on the end you pinched before, and bend the stack the other way. Repeat.
With every bend, the stack gets more slanted. Now hold one end of the stack and fan the other end to get air between all the sheets. Fan the other end the same way. The tiny layer of air you're creating between pages goes a long way in lubricating them, so they feed separately.
Straighten the stack and put it back in the cassette. The blue "fences" at the sides should be touching both sides of the stack to provide a little friction and keep the feed straight. The back fence should hold the stack against the opposite end of the tray. (Your tray is slanted at the feed end. On models where that wall is vertical, you should have a 1 to 2 mm gap so the paper doesn't bind when it tries to lift.)
Reinsert the tray and try it out.
Dec 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
My photocopier sharp z810 is not accepting paper.how do i rectify the fault or problem.i need a solution please.
if there is paper in the paper tray but the machine still says no paper, then the paper end sensor is broken in the tray. take the paper tray out and you will be able to see a sensor on top. when the tray is fitted the sensor is on top of the paper. the paper lifts the sensor to activate. i am a photocopier technician.
Oct 01, 2010 | Sharp Office Equipment & Supplies
Canon NP 6650 photocopier. Begins to pick up paper, stops and gives message about jammed. Checked path and see no paper or parts of paper. Need service manual.
1)jammed issue.
2)can u try to make copies by using stack bypass or other paper deck see whether u hav the same fault.
3)or flip over your paper and put it in the paper deck again .Fan the paper ,it could be high moisture and static on the paper.
4)clean the paper dust from the pick up unit with damm cloth.
Sep 04, 2009 | Canon Office Equipment & Supplies
This stupid all in one won't let me do anything
Does the machine grab several sheets at once and eject them, or does it eject one piece after another until the stack is gone?
Jun 02, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Ricoh Nashuatec MP2000 Toner 9000 Yield Type 1130D - Genuine OEM toner Logo
47 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
