Question about Bosch Dishwashers
How can i test the aqua stop as i am not getting water in the washer
    New Friend:
Really need a model number before giving advice on how to check the appliance
Posted on Nov 21, 2014
How do I get to make it stop and work .Dishwasher is not shutting down it says E 15 Water tap flashing , and red Aqua stop light .
inlet valve is the aqua stop long hose to tap has a solenoid at tap end that is likely your fault
Sep 29, 2016 | Bosch Dishwashers
How do i test the aqua stop is working as i am not getting water in to the washer
You either have a Block of the HOT WATER LINE (where the hose screws into the Washer in the back of the Washer, Bad selector Switch or Circuit Board. Change the Selector to COLD and does it fill up? If it does, then change to HOT. If the water complete shuts off, then you need to disconnect the HOT LINE and then check the Filter and check the Water Flow of the hose. Hope this helps....
Nov 14, 2014 | Bosch 607335 Water Valve Assembly For...
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
Thermostatic valve does not turn
followt this steps and fix it. God bless you
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Nov 28, 2013 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
I have a Kenmore 500 series washing machine. The cold water just trickles out but the hot is fine. I have replaced the fill valve, but the problems persists. Any help would be appreciated.
Having replaced the valve i would suspect the cold water for what ever reason is not getting to the valve from the faucet..if you have not already done so remove cold water hose and see how much water is coming from it when its not connected to the washer. If your using the "aqua flow-flood stop" hoses thats going to be the problem..the internal stopper in the hose has failed and hardly no water coming through the hose.
GENE
Aug 28, 2011 | Kenmore 24422 Top Load Washer
I get an F H code. I bought a new inlet value which fixed the problem for about two weeks. I then installed the old one wich lasted another 2 weeks. How can I find and fix the correct problem. Maytag ...
As i suppose you know by replacing the water inlet valve that the F-H error code means now water was detected entering the washer. having replaced the water valve,one thing you should check,espically if using"aqua flow flood stop" braided steel inlet hoses from the house water supply,is if water is flowing through the inlet hoses into the washer, if your using that type of hose from the faucet they have a problem in them and the internal flood stop device inside the hose fails and even though the water faucets are on no water is getting into the washing machine. Also or even if using those type hoses disconnect them from washer and check for water flow through them when not connected to washer. If water flow is good into washer replace this part called the flow meter part # W10110225 it measures and tells the control that water is coming into the washer. It the flow meter can of course be purchased where you got the water inlet valve.
Good luck,
Gene
Aug 19, 2011 | Maytag EPIC MFW9700S Front Load Washer
I want to disconnect the water supply. I am replacing this 12 year old slimline smeg dishwasher and they are coming to take it away to morrow. The connection to the water supply is via a grey plastic box...
Hello Henry,
It's the aqua-stop safety valve and yes, you can just unplug it. Make sure you close the valve on the water-supply first or it's going to get rather messy!
FYI, the aqua-stop is a second-level safety device which shuts off the water supply to the dishwasher to prevent flooding if a leak is detected, when there is no power to the washer and in certain other error conditions.
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Apr 19, 2011 | Dishwashers
I need a user's manual for SGS5302 bosch dishwasher. Otherwise would you tell me exactly how the aquastop works? Is there any method to bridge it? What goes on the wires? Signals from or to the...
Please rate this solution if you find it helpful. Thanks!
The Aqua-Stop function is a flood protection feature. You really don't want to be "bridging it"!
It works by using a float switch to detect when the water level gets too high in the wash compartment. It over-rides any wash programme and starts the pump to empty the water out.
Also if water leaks into the bottom of the dishwasher (under the washing compartment) the float will rise with the water level and when it reaches a critical point, it will over-ride any washing programme and run the pump.
However, the pump cannot remove water from under the washing compartment, but as it over-rides the wash programme, it prevents the washer from continuing with any wash cycle, thus preventing any more water from leaking into the bottom of the washer and flooding your house.
For this reason, you should never attempt to "bridge" (whatever that means) modify or disable the aqua-stop feature. If it's been activated, you have a problem which needs to be resolved before you continue to use the washer.
Here is a direct link for downloading your manual from Bosch (free):
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Oct 16, 2010 | Dishwashers
Aqua stop activated
A simple problem can disable a washing machine: if water runs back into a washing machine from the drainage hose, then the aqua-stop engages. This can happen due to a defective water pump.
In this case it could help to tilt the washing machine so that the water drains and the aqua-stop is deactivated. (Of course you’ll have to fix the cause of the problem beforehand).
Thank you for contacting Fixya.com
Aug 06, 2009 | Bosch Washing Machines
How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Jul 09, 2008 | Bosch 24 in. SGS43C02 Classixx Built-in...
Dishwashers Logo
209 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
