Question about Toto MS604114CEFG03 1.28GPF One-Piece Elongated Toilet with SanaGloss
I have a toto toilet , model MS604114CEFG , installed 2 years ago . Last night , I did not succeed to flush it after usage . When you flush , the water come back , the tank fill back to the normal lev
I have a toto toilet , model MS604114CEFG , installed 2 years ago . Last night , I did not succeed to flush it after usage . When you flush , the water come back , the tank fill back to the normal level , but in the toilet. The water remain high . What can I do to resolve the problem ? Thanks for your help
    Top Expert:
  • Toto Master
  • 34,186 Answers
Use a plunger to unclog the bowl.
Posted on Nov 14, 2014
4 Suggested Answers
  • 12104 Answers
SOURCE: Our Toto ultramax model MS853113S will constantly
flapper most likely needs to be replaced not sealing completely is one problem----- the other is float level not shutting off water valve --and other is bad water valve not shutting off or worn and needs to be replaced remove cover and turn water on watch water level lift float up if water turns off valve good----turn off water if drain down flapper bad and needs replacement costs a couple of dollars to replace -if water stays level in tank than float needs adjustment or replacement
Posted on Aug 02, 2010
  • 4336 Answers
SOURCE: Toto one piece toilet intermitnently
This sounds like an inlet valve issue, or possibly a sunk float. Replace as needed. There should be a chamber that is LOWER than the handle, that would allow water to flow down into the bowl, is this item too tall?
Posted on Mar 02, 2011
al_kupchella
  • 843 Answers
SOURCE: The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Posted on Jun 15, 2012
I have a toto toilet , model MS604114CEFG , bought 2 years ago . Last night , when I flushed it , the water level in the toilet bowl did not come down . It stay high in the bowl . In the tank reservoi
If the toilet is the only fixture in the bathroom group that is having an issue, then there is a partial blockage in Strap of toilet or in drain pipe close to toilet. If other fixtures are showing sluggish drainage, then the main drainage line is clogged. If all is fine with tub lav shower etc., pull toilet from floor and carefully turn upside down, and look to see if anything is visable. if so remove it and reinstall with new seal(wax ring). Also, look into pipe and see if any water is standing in it. If water is standing in pipe, the drain line is clogged and must be rodded(snaked) out to cure problem
Nov 14, 2014 | Toto MS604114CEFG01 UltraMax II Toilet,...
Which toilet is best?
I replaced the 2nd floor toilet in my house several years ago. It has all the features you require, except the 17" tank width. If you can fit a 20" tank ( actually 19 3/4") then the brand to buy is Toto. The quality is unsurpassed.
The (included) *seat* height is 16 1/8". GPF is 1.6, but the flush is amazingly powerful. I opted for the special self cleaning coating they call "Sana Gloss". Nothing sticks to it, it doesn't stain, and I've never had to use a toilet brush nor bowl cleaner on it the whole time I've owned it.
I bought mine from an online distributor. Just Google "Toto". I haven't checked recently, but they may have a narrow tank model. Mine has the extended bowl.
Apr 15, 2014 | Home
Flush Valve leaking
replace the whole valve. It's cheap and easy to do. Probably you can install a universal valve. Look on e-bay or amozon
Dec 05, 2012 | Toto Aquia II Dual Flush Toilet
I bought 2 toto toilets about 7 years ago. One toilet has started to experience about a 2 to 3 second delay from the toilet discharge to the refill. I replaced the flapper ball but no change in the flush....
jasether-
The fill valve is most likely corroded with mineral deposits. You can either try to clean it or replace it (these cost just a few dollars). Remove the old one and take it to a plumbing supply or hardware store to properly match the replacement.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Home
I can hear a dripping of water but the washer is fine. The water tap is turned down low, I'm a female and not familiar with the makings of a toilet cistern how does the centre flushing mechanism come out....
Anytime that you have water dripping between flush cycles, it is caused by water leaking through the flush valve. Without being able to look at it I would recommend placing the entire flush valve assembly (flush ball/plunger and the valve seat (washer). The part is not expensive, although the labor may be. You could replace the flush ball or plunger (whichever type it is) yourself and that may correct the problem.
Nov 26, 2010 | Toto Aquia II Dual Flush Toilet
Toto flush handle problem
did you try a new flapper? sometimes those are the reason they wont flush properly. check out the american standard cadet 3 it's half as much as a toto and works just as well
Jul 13, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
I purchased a Toto Aquia II Dual Flush Toilet, around a year ago. No problems until now. The toilet won't flush. It doesn't appear to be running at all.
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Jan 14, 2009 | Toto Aquia II Dual Flush Toilet
Toto MS604114CEFG03 1.28GPF One-Piece Elongated Toilet with SanaGloss Logo
347 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
