Question about Bosch 607335 Water Valve Assembly For Dishwasher
How do i test the aqua stop is working as i am not getting water in to the washer
    Top Expert:
  • Bosch Master
  • 2,044 Answers
You either have a Block of the HOT WATER LINE (where the hose screws into the Washer in the back of the Washer, Bad selector Switch or Circuit Board. Change the Selector to COLD and does it fill up? If it does, then change to HOT. If the water complete shuts off, then you need to disconnect the HOT LINE and then check the Filter and check the Water Flow of the hose. Hope this helps....
Posted on Nov 14, 2014
How do I get to make it stop and work .Dishwasher is not shutting down it says E 15 Water tap flashing , and red Aqua stop light .
inlet valve is the aqua stop long hose to tap has a solenoid at tap end that is likely your fault
Sep 29, 2016 | Bosch Dishwashers
How can i test the aqua stop as i am not getting water in the washer
really need a model number before giving advice on how to check the appliance
Nov 14, 2014 | Bosch Dishwashers
AEG Favorit 44090i Dishwasher will not fill with water
There may be a filter after the aquastop pipe which is blocked. This is usually at the back of the inlet valve. Also, the inlet valve may no longer work.
Nov 07, 2014 | Dishwashers
AEG Favorit 44080i Dishwasher will not fill with water
Well, this was very long-winded. If it works when filled manually, then check the stopcock for the water flow and open it more if not all the way. If this does not work, try the water pump in the back/bottom of the disher
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
Thermostatic valve does not turn
followt this steps and fix it. God bless you
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Nov 28, 2013 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
I want to disconnect the water supply. I am replacing this 12 year old slimline smeg dishwasher and they are coming to take it away to morrow. The connection to the water supply is via a grey plastic box...
Hello Henry,
It's the aqua-stop safety valve and yes, you can just unplug it. Make sure you close the valve on the water-supply first or it's going to get rather messy!
FYI, the aqua-stop is a second-level safety device which shuts off the water supply to the dishwasher to prevent flooding if a leak is detected, when there is no power to the washer and in certain other error conditions.
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Apr 19, 2011 | Dishwashers
I need a user's manual for SGS5302 bosch dishwasher. Otherwise would you tell me exactly how the aquastop works? Is there any method to bridge it? What goes on the wires? Signals from or to the...
Please rate this solution if you find it helpful. Thanks!
The Aqua-Stop function is a flood protection feature. You really don't want to be "bridging it"!
It works by using a float switch to detect when the water level gets too high in the wash compartment. It over-rides any wash programme and starts the pump to empty the water out.
Also if water leaks into the bottom of the dishwasher (under the washing compartment) the float will rise with the water level and when it reaches a critical point, it will over-ride any washing programme and run the pump.
However, the pump cannot remove water from under the washing compartment, but as it over-rides the wash programme, it prevents the washer from continuing with any wash cycle, thus preventing any more water from leaking into the bottom of the washer and flooding your house.
For this reason, you should never attempt to "bridge" (whatever that means) modify or disable the aqua-stop feature. If it's been activated, you have a problem which needs to be resolved before you continue to use the washer.
Here is a direct link for downloading your manual from Bosch (free):
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Oct 16, 2010 | Dishwashers
Aqua stop activated
A simple problem can disable a washing machine: if water runs back into a washing machine from the drainage hose, then the aqua-stop engages. This can happen due to a defective water pump.
In this case it could help to tilt the washing machine so that the water drains and the aqua-stop is deactivated. (Of course you’ll have to fix the cause of the problem beforehand).
Thank you for contacting Fixya.com
Aug 06, 2009 | Bosch Washing Machines
How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Jul 09, 2008 | Bosch 24 in. SGS43C02 Classixx Built-in...
Bosch 607335 Water Valve Assembly For Dishwasher Logo
135 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
