Home | KitchenAid | KSB3 Classic Work Top Blender | Rubber wheel that bla...
KitchenAid KSB3 Classic Work Top Blender
Problem for KitchenAid KSB3 Classic Work Top Blender
Rubber wheel that blade goes on, how do I replace
By rhodamoore on Jul 06, 2009
Rubber wheel that blade goes on, how do I replace it?This is the wheel that makes the blade go around. Mine has broken into pieces and can not use blender.
Best Solution
posted on Jul 07, 2009
Very Helpful)
QuietRiot
Rank: Guru  KitchenAid Expert
Rating: 93%, 84 votes
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for KitchenAid KSB3 Classic Work
Questions and Unsolved Problems for KitchenAid KSB3 Classic Work
Do you recommend KitchenAid KSB3 Classic Work Top Blender?
Answer
Answer
looking to get armature for blendtec 12098
Answer
the black piece on the base that turns the blades has deteriorated an broken apart
Answer
the bobby flay blender leaks out the bottom where the blade is screwed in
Answer
Using the Kitchenaid blender (model KSB85) and the motor just turned off. Now power to the unit... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For KitchenAid KSB3 Classic Work...:
Top Blender Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
