Question about Samsung GT-E1270 Black Mobile Phone - Unlocked 208 MHz Processor, SNMP Platform
How can I prevent it putting a call on Hold when I want to end the call.
  • Samsung Master
  • 5,428 Answers
Press the end button again!
Posted on Nov 14, 2014
Trying to get the inner cv joint off on 1999 hyundai accent, do i need to undo the ball joint or take the disc rotor off?, any advice would be much appreciated. Thanks Adam in New Zealand.
The rotor has nothing to with cv joint, Try to take off tie rod then you twist and pull back cv joint I did on Toyota Yaris.live nut on at the end hit with a hammer will pop out. to put back may you need a clamp to hold together prevent from spin.
Jul 30, 2017 | Hyundai Cars & Trucks
Needle clamp
Take a smaller flat ended screw that will fit easily into the hole sticking out the end. Grease the outside of the smaller screw but not the end. Put a TINY drop of superglue on the end and hold it to the part of the screw stuck in the hole. After 30 seconds, gently unscrew them. Be careful that there is not too much glue. (The grease should prevent the glue to sticking to the side of the screw)
Oct 28, 2013 | Bernina Artista 180
Where the heck is the reservoir for the clutch master cylinder on my 84 AMC Eagle.
its made on clutch master cylinder under hood straight thru from clutch pedal fill it under hood take small wrench 5/16 I think get under vehicle find slave cylinder bleed valve you will need wrench a piece of vacuum hose and a cup put wrench on bleed valve then put vacuum hose on next the other end goes in cup of brake fluid to prevent air sucking back it can bubble air out but can only suck brake fluid back have helper pump clutch pedal hold pedal bleed repump rebleed till clutch gets right its harder to bleed than brakes pump fast hold pedal down pump clutch fast hold down bleed real pain in *ss good luck
May 21, 2013 | 1984 AMC American Motors Eagle
Error message is 5Ud5
CODE SYMBOL = 5Ud5
MEANING = Too many suds are detected during the washing session.
The unit is put on hold until the suds are reduced. Then, the unit will go back to the operation.
When it finishes washing, End and SUdS codes will blink in turn
SOLUTION = To prevent it, cut down on detergents.
Jan 07, 2012 | Samsung WF337AA Front Load Washer
Suspension strut keeps spinning when i trying to remove it to repace spring
Most struts will have a hex shape (or perhaps two parallel flat surfaces) on the very top of the shaft to put a socket (or end wrench) on to hold while loosening the main hex nut.
This procedure would require the use of both hands (one to pull on wrench of main nut while other holds wrench to prevent shaft from turning)
Would not suggest, however, that you hold the shaft with pliers or pipe wrench. This could damage threads, making it difficult (if not impossible) to fully remove main hex nut.
You mentioned changing the spring....do you have a spring compressor?
Jan 30, 2011 | 2002 Hyundai Accent
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
The control is locked when a single beep is heard and the Control
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
NOTE:
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
until the control is unlocked.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I can't put back the top dishwasher rack. The railing does not seem to hold it, even though there is no damage in the railing. The top rack could not be held by the rollers
There should be plastic stops at either end of the rail that prevent the rollers of the rack from coming out of either end.
Sep 22, 2009 | Maytag Dishwashers
NEEDING TO PUT THE COLOR DRUM BACK INTO THE PRINTER. TRYING TO PUT THE COLOR DRUMS BACK INTO THE PRINTER
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover theprint cartridge with a sheet of paper.
1.Open the print cartridge door, and remove the old print cartridge. See the recyclinginformation inside the print cartridge box.
CAUTION
To prevent damage to the print cartridge, hold the print cartridge at each end.
2.Remove the new print cartridge from the packaging, and gently rock the print cartridgefrom front to back to distribute the toner evenly inside the cartridge.
3.Pull the tab until all the tape is removed from the print cartridge. Put the tab in the printcartridge box to return for recycling.
4.Insert the new print cartridge in the printer, making sure that the print cartridge is inposition. Close the print cartridge door.
CAUTION
If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water.
Hot water sets toner into the fabric
You can see the pictures of it at: http://www.scribd.com/doc/4212097/hp-laserjet-1020-users-guide-manual
Jan 14, 2009 | HP LaserJet 1020 Printer
Samsung GT-E1270 Black Mobile Phone - Unlocked 208 MHz Processor, SNMP Platform Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
