Question about Hitachi Televison & Video
The red light is on for power,but it does nothing now
I think the model number is ,,57f70,,other numbers are 275w 40a
  • randy wellman
    randy wellman Nov 14, 2014
    57f710s is the model number
    Top Expert:
  • 2,044 Answers
Is the Lens Cap On? I had an Instructor do that once, there is also possiblity of Cable Issues, Software Mis-Match, Improper Settings.....
Posted on Nov 14, 2014
3 Suggested Answers
charcois
  • 763 Answers
SOURCE: no power protection red light
try to check the cord from the outlet to your tv. it must be loose or something. off your tv for about 2 minutes and open it again.
CHARCOIS
Posted on Sep 15, 2008
SD Tech
  • 14553 Answers
SOURCE: the red light is blinking and the tv want come on
First on this model remove the lamp and examine it to see if shattered inside---customer replaceable and door (unplug set first) is on left side as seen from the front.
With door off remove two brass screws and grasp handle on lamp cartridge and slide it out---with the screws removed the lamp cartridge just slides out--pull it out and look.
Posted on Mar 24, 2012
I have 42" ,Sansui plasma tv .model number Sty 0342 . when i switch it on , the power led chages from red to blue, then suddenly goes red again .i've changed the power board but it keeps doing the same...
I have sansui television 42"model number STY0342, plasma 3D.when l turn it on sometimes it takes time to switch on after turning it on.it will change the standby light to blue.what might be the problem.
Dec 26, 2013 | Televison & Video
We have a model AD-40A dehumidifer that I believe is approx 3 years old. When the unit is plugged in, nothing happens. Although it appears to be getting power (when you pull out the water tank, the...
You may have the humidity extraction level set to HIGH. Try lowering the humidity extraction level to 35% or if you have an analog unit, turn the control knob to maximum. Also cleaning the air intake filter may help.
Hope this helps you to solve the problem and thanks for choosing FixYa.
Aug 17, 2011 | NewAir AD-40A Dehumidifier
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
Hi LG RZ37LZ55 The Ir sensor in the TV has stopped working. Does anyone know the part number and where i could buy one.
I need the correct Model# the one you have posted list different TVs Look on the Back of your TV for Model/Chassis#
Dec 30, 2009 | Televison & Video
Turn tv on tv nothing happend red light blinks 3
O would need the model number to assist you, as the s blinks is an error code, but error codes are model specific.
Nov 26, 2009 | Televison & Video
I have a dell 5150c with a blown nps 275bb 275w p/supply i have tried chaging it with 2 220w ones but amber light flashs indicating problem it will run off a full size power supply 600w must i get a 275w...
Any power supply should work as long as it's the proper minimum wattage. You only need to make sure that it has the power connectors you need for your system. T'here is nothing wrong with buying a 400 watt P/S or larger. Many systems have under powered power supplies if you add onto or upgrade your system. For example when building systems you need to calculate how much ram memory your system will have and you need so many watts for each gig of ram. Dells normally come with under minimum required ram so they don't put very good power supplies in their systems and when people upgrade the ram the power supplies are usually inadequate.
Nov 22, 2009 | Computers & Internet
Blinking Red Light - Nothing Works
Call Sony, give them serial number (rear of unit) provide descripton of problem and failure to operate after powering off and they will issue a case number and give you an address in Lubock TX to send the unit. Send the unit, with the case number showing on the shipping label, include a proof of purchase, description of problem, return address. Also if you like me, have CD's in the changer make sure you note that during the telephone call with Sony and again on the description of problem. Very fast phone call.
Oct 20, 2008 | Sony CMT-CPX22 CD Shelf System
42" Panasonic plasma has no picture, but power light is flashing
I think accroding to your model number this unit is plasma.
I need to know red light how many times flashing and correct model number
Sep 18, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
