Question about Ricoh Aficio Office Equipment & Supplies
Have they changed sp mode entry on the new control panels, ie mp2553?
Have tried the old 107 etc, can`t get in
  • 3 Answers
Clear All, 806182, Clear
Posted on Nov 14, 2014
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
MP C5502 Service Mode
Yellow 182806 clear/stop is the new code for color units. Ricoh changed it last year. You can reset it in sp mode 5 back to old if needed.
Mar 30, 2012 | Gestetner Office Equipment & Supplies
I need code for tv RCA
Hello
Three digit universal remote codes for RCA TV are:
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit codes are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search Method
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Oct 29, 2011 | RCA 46 46LA45RQ LCD TV
Tv coddetv #19la20qw
Hello
Setup codes for proscan TV are:
0031 0107 0015 0000 0162 0163
Three digit codes are:
000/ 031/ 107/ 181
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Jul 28, 2011 | Proscan 19LA20Q LCD TV
Useing a universal remote doesnt work for it
Hello
I don't know which remote contro handser are you using to synchronise with your tV. Anyway I'll give you some codes for RCA TV here. Try with them.
Direct Code Entry
OK.
Jun 25, 2011 | RCA L32HD31 32 in. LCD HDTV
How do i get the code for my rca colortrack tv?
Hello
Three digit universal remote codes for RCA are:
Four digit universal remote codes for RCA are:
Direct Code Entry
Mar 20, 2011 | RCA Televison & Video
What SC 541 is ?
sc 541 is a fuser error code. try these steps
press clear mode once
press 107
press clear/stop and hold it untill your screen changes to copy sp mode.
press copy sp on screen
off and on the machine. it shud reset its code. i am a Ricoh tech. email me if you are having difficulty. ronils_singh@yahoo.com.au
Oct 01, 2010 | Ricoh Aficio 450 Copier
My Ricoh Aficio copier 2051 the problem is SC 863-13 can u solve it?
SC 863 indicates that there are bad sectors in your machines hard drive. You have two options. First, try to have your hard drive re-formatted (you do this through the control panel in the service mode) but beware, any documents stored in the document server will be deleted and so will the scan to folder pre-programmed in the machine.
Second option, assuming the re-formatting did not work, would be replacing the hard drive altogether
Hdd formatting procedures:
service mode entry: press clear modes, press 107 then hold down the clear stop red button for 10 seconds, screen will then change. select copier, then upper right side select "sp direct" then punch in 5832.
Execute 5832 001 to format the HDD.
Jan 15, 2010 | Ricoh Office Equipment & Supplies
Error Aficio 550
reset the problem first if don't work then replace laser unit
1, press "clear mode" on up-right of panal.
2, enter 107
3,press and hold "clear/stop" for 3-5 second
4, turn power off and on
Dec 12, 2008 | Ricoh Aficio 450 Copier
46 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
