Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Video screen is scrambled
My video screen is scrambled and looks like the nightshot is on. It is green and black in color. It does change the brightness when nightshot is on. It started last Christmas while I was using it. It was clear then after turning it off and back on it started do this. I have once been able to get it to turn on clear again but it was just turning off and on. When I record it plays back scrambled but if I playback a previous recorded tape it plays back clear.
Thanks in advance.
  • 2 more comments
  • brando2812 Nov 15, 2007
    Thank you Rickybig.
    I found deep in the Sony website that this is a know problem and are fixing it for no charge.
    See link below.
    http://esupport.sony.com/perl/news-item....
  • Anonymous Dec 10, 2007
    Had the same issue. Just wanted to say thanks for the info and link because I would have ended up just throwing away this camera, because the estimates I got were over $250.
  • Anonymous May 04, 2008
    Exact same problem--am checking links now to see how to fix
  • Echalotte May 05, 2008
    I have the same problem.
I ALWAYS use sony tapes for my camcorder, but had exactly the same problem- the 'nightshot' type effect just appeared out of the blue. the best thing to do to solve this problem is to firmly SMACK the camera with the palm of your hand- firmly- on its side. i swear i'm not kidding- this REALLY works. Read this on another site searching for a solution, though my lcd was also showing a c32 error or something along the lines.
Posted on Apr 04, 2008
  • 67 Answers
Bad tapes ive seen it before ..buy a different brand brandnew ones and give it another go.
thats why other tapes are working.
Posted on Nov 15, 2007
Green and blue faded
Some of these had bad picture tubes--(model indicated here uses 3 tubes)
Simple test is go to a black and white channel and turn color to zero= is the screen black and white or some other color?
Also go to a unused video input and look at screen=all you should see is black screen with the input number in green= any other color and something may just need to be adjusted.
Apr 15, 2012 | Sony KP-65WV700 65" Rear Projection HDTV
MY SCREEN LOOKS LIKE THE MATRIX MOVIE. IT IS
The most probable cause is that your video driver is not up-to-date. Try updating your video drivers as soon as possible. You can download all the latest drivers (for Windows XP only) for your laptop from here.
Download all Drivers for Xp
For other Operating Systems, just search online for the drivers compatible for your laptop model mentioning the OS.
Dec 14, 2010 | HP Pavilion dv9000z Notebook
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Can't turn off nightshot on my handycam help!!!
Option 1:
Using the NightShot:
1. First Set the POWER Switch to Camera, Slide NIGHTSHOT to ON.
2. The NIGHTSHOT indicators flash on the screen.
3. To cancel the NightShot mode, Slide NIGHTSHOT to OFF.
Option 2:
1. Let us try to reset the Camcorder and check if it helps to resolve the issue.
2. Locate the RESET button behind the LCD screen of the Camcorder.
3. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Green display on boot up Please help
Check to see that there are no machine BIOS settings that could affect the monitor. Normally, the bios controls display until the OS takes over. If your XP screen after bootup looks fine, I don't see how you have a problem with your monitor setup under Windows.
Jul 03, 2009 | Computers & Internet
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Ccdtrv608 sony handycam stuck in nightshot mode
Below image of CCD-TRV608 shows NightShot Button location, turn it Off for normal mode recording.
Mar 24, 2009 | Sony Handycam CCD-TRV68 Camcorder
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
180 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
