Why does my samsung washing machine only fill water for a couple seconds and then stops?
It drains all the water but cannot fill up at all thought it was on time delay switched off and on several times but still cannot complete a cycle
    Top Expert:
  • Washing Mach... Master
  • 14,161 Answers
SAMSUNG CUSTOMER SUPPORT PHONE NUMBER:
1-800-726-7684
M-F
9-9 EST
Posted on Nov 14, 2014
SOURCE: Washing machine wont stop filling up
check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
Posted on May 29, 2008
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
  • 1937 Answers
SOURCE: Washing machine stops after wash agitation cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Apr 30, 2010
Testimonial: "At least at this point I know where to begin to make repairs. I will let you know just how things have worked out. Thanks, Ken Beals"
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
Jul 12, 2010 | Estate ETW4100SQ Top Load Washer
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
New to this Machine. Unit washes and stops every 25 seconds?
Have you contacted Malber USA? 516-294-6660. They were helpful with my problem.
Aug 17, 2007 | Malber WD1000 Front Load Washer/Dryer
Smelly water
? How about Filling the machine with a suitable detergent bleach solution leave a couple of hours then pump out. Also this is likely to be a grease/soap crud build up in the pump and drain system So attention to the drain hose, Detach and seal one end and fill with hot detergent and leave then remove the plug to allow to drain. It is the drain area most likely the cause.
Jul 28, 2007 | Whirlpool Ultimate Care II GSQ9669L Top...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
