I have a P4i65gv motherboard. Tomorrow I was just start my computer. UNKNOWN BIOS ERROR. ERROR CODE =FFFF PRESS F1 TO RESUME
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
The board is an Asrock board, socket 478, and therefore quite elderly. You can download a manual for this board here.
ASRock P4i65GV
This error is quite common and can often relate to Hardware, but is given for a variety of reasons and has a variety of solutions. I give a few below:
1. Enter BIOS (usually Del or F2 during early boot) and set to default settings. Whilst in BIOS check that hard drive, optical drive, and memory are all accurately detected. Reboot and see if they work.
2. Clear CMOS, the manual will tell you how to do this. It is usually a 2/3 pin header with a jumper across 2 of the pins. To clear the CMOS the jumper usually is moved to the other 2 pins under certain conditions.
3. If you have more than one memory module try them each individually. Turning off the computer and rebooting with each one on its own.
4. Try rebooting after disconnecting the hard drive.
Don't forget whenever working inside the machine turn it off, disconnect from the mains and make sure you are grounded do that there is no static around which may damage parts.
Having tried the above you are heading towards the realm of CPU failure or part of the motherboard having failed, and needing replacement for the computer to work and I doubt the economic sense of this, unless you get used parts from eBay or something like that. The money my be better being put toward a new or better 2nd user machine.
Hope something here works
Posted on Nov 14, 2014
2 Suggested Answers
pappapumpdaf
  • 635 Answers
SOURCE: every time I on my
You need to flash your bios before it becomes totally corrupted. You are losing small bits of information that your motherboard needs to continue functioning.
I have what i believe is the proper page for your bios, but your exact model doesn't show up when I search the site, so the best solution for your problem is the MSI live bios update located at the bottom of this webpage:
http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1150
Simply install that and allow it to automatically fix your bios for you.
Posted on Aug 05, 2010
Emachines pc unknown error code 8302-press f1 to continue
http://www.tomshardware.co.uk/forum/295726-30-bios-error-code-8302 READ IT.IT EXPLANES THE PROBLEM.
Apr 05, 2013 | E-Machines eMachines Desktop PC
Hello, I went into my bios settings and did something wrong now when I start up my computer it takes me to the mi bios megatrend screen at the bottom of the screen says driver bad press f2 to resume f1...
go back into the BIOS by pressing F12 and look for the set BIOS to default values or something along those line. save those settings and reboot..
Please give feedback...
Dec 18, 2012 | Lenovo Computers & Internet
Every time I on my PC it appears in screen unknown bios error. error code 8302 press f1 to resume
Aug 05, 2010 | MSI P4M900M-L Motherboard
UnKnow Bios error Error Code =8302 Sr, Computer Opening No Display ....F1 Press Continue Display Ok
Hi, this can be caused by a BIOS update or a faulty motherboard battery. You can reset BIOS to default settings by pressing the F1 key during bootup, which will take you to the BIOS screen.
Aug 04, 2010 | MSI P4M900M-L Motherboard
Asus bios problem
Unless there is a compelling reason to update the bios it should be left alone. Apparently this is one reason for that sage advice.
Go back to asus, download an older version of the bios and install it. Fortunately you didn't end up unable to boot or you would be buying a new board.
Apr 29, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
ECS 945gct-m2 CMOS error
When you enter the bios...go to the setting where you have the option your reset the bios to manufacturer...Once you do that it will work without any problems...It sounds like the bios setting might have been accidentally modify..
Hope that helps
Thank you
Mar 06, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Press F1 to resume
Try changing the CMOS battery (leave the battery out for 5mins then replace with new 1) if that does not work flash the BIOS
Let me know how you get on...
Matt
Dec 08, 2008 | MSI K9VGM-V Motherboard
Problem after updating asus bios
The first thing I would try is to clear CMOS. Either set the jumper on the motherboard to do this, or even remove the battery, and wait half an hour or so. When installing a new CPU, and even RAM, you should always clear CMOS.
Cheers
Nov 11, 2008 | Computers & Internet
Code error
first you reset the BIOS remove CMOS battery or shorting it with jumber. this may give solution
Jul 05, 2008 | ASUS P5PE-VM Motherboard
A disk read error occured
Your system BIOS no longer recognizes your processor. I'm going to assume you haven't replaced the processor recently, in which case it is a bios error. Can you enter the bios on startup, or does this occur before that? On most computers there will be a message saying something along the lines of "press F1 to enter setup" - of course, it could be F1, F2, F10, F11, F12, DEL or ESC... or possibly another key Try hitting all of those and see if it takes you to a BIOS menu. If you can't get to the BIOS, you're going to have to replace the motherboard. If you can get into the bios, you may be able to detect your processor from there. Without knowing specifically what bios you are using, or what motherboard so I could find the bios information, I can't say more. If you can get into the BIOS, it should tell you what version it is (usually on the top somewhere). Get me that information and we can go from there. If you can't get into the BIOS, it's time to replace your motherboard. Or, honestly, for a system of that age it might be cheaper to just buy a new (or used) computer to replace it.
Aug 28, 2007 | Intel Pentium III, 800MHz (229725001)
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
