Question about Hardware & Accessories
My son has tried to reset the timer on our C140t. 1've just read the instruction manual and it says not to turn the out side dial., which he did. now nothing is working, including the manual over ride
My son has tried to reset the timer on our C140t. 1've just read the instruction manual and it says not to turn the out side dial., which he did. now nothing is working, including the manual over ride switch. What can i do. Am i able to rest some how? Tania
  • 5,089 Answers
What exactly is C140T?
Attach photo
Can you find manual online that I can read along with you?
Re-post question with more detail
Water Heater Timers Save Money
Posted on Nov 17, 2014
  • 112 Answers
SOURCE: timer wont turn on, is the manual switch below the
the manual switch is to override the timer and turn on what its controlling, for the timer part to work it is supposed to be in the off position, this should let the timer work like its supposed to.
Posted on Aug 21, 2009
MOTORWIZJ
  • 1339 Answers
SOURCE: The timer does not operate. Breaker flipped once.
START YOU VOLTAGE CHECK AT THE BREAKER , IF YOU PUMP IS 230 VOLT THATS WHAT IT SHOULD BE ABOUT 230-240 V . YOU CAN ALSO CHECK IT AT THE TIMER AT THE 2 SCREWS THAT SAY LINE (NO VOLTS ITS A BAD BREAKER) AND THEN CHECK THE 2 SCREWS THAT SAY LOAD WITH THE TIMER ON "MOTOR RUN" (NO VOLTS ITS THE TIMER)
Posted on Jun 03, 2010
SOURCE: The timers on my Intermatic Timer T40003RT3 are
Sounds like clock motor(s) are working.
Snap mechanism out using thumb spring located inside top of box.
Look for clock motor number printed on clock, should be WG1573 for 240V timer
Google search for 'Intermatic WG1573'
For example Grainger sells that clock motor as 1PNK2
(plus they sell extra trippers which are designed to wear down):
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 05, 2011
SOURCE: timer not working on 4000
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
Posted on Aug 29, 2011
SOURCE: I have only Black, White and Ground where the
Question posted under Woods countdown timer.
Open following links to identify timer and see how to wire this timer:
http://waterheatertimer.org/Programmable.html#wire
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Additional resources:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Woods series countdown timer is rated 1/4 Hp, and is suited for lights and bath vent fans, but not whole house fan.
Posted on Sep 23, 2011
How do I set a 24 hour timer D809/1
HPM 24 hour timer instructions: rotate dial clockwise until current time lines up with pointer located on inner dial. There are segments located around edge of dial. Pull up these segments to set on-off times. Turn Load switch ON. Plug Load into timer. Plug timer into receptacle. Manually rotate dial clockwise and observe Load turning ON-OFF. This will show if timer is ON or OFF when segments are pulled up.
I think the D809/1 has 15 minute intervals. The only manual on the HPM site for a 24 hour timer close to this is:
https://hpm.com.au/app/document/asset/23/16/6/d8180d-hpm-24hr-outdoor-timer-instruction-sheet.pdf
Sold at Bunnings in Australia, you might find a manual with one! Alternatively, here is another place they are sold and given they are inexpensive, it might be worth it to just get the instructions. Amazingly, if you try to search for a manual for this, you can not find it. You just get comments like the techs were not help, the manual was in Chinese, and after translation, were not even understood by the techs. Heaven knows what the truth is. The HPM manual above is clearly in English. Note the device manual above likely is set for half hour intervals. Good luck.
http://www.radioparts.com.au/ProductDisplay.aspx?popup=1&Category=SXKK1045&Product=49161200&ProdDesc=D809%2F1+24+HOUR+ANALOGUE+TIMER+HPM
Aug 11, 2017 | Hardware & Accessories
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
http://waterheatertimer.org/How-to-set-timers.html
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
Trying to set my malibu power pack and need directions
That's because you have the timer (dial) mode set to "auto" Turn the dial to "Timer" mode, then follow the directions in the manual. You will also have to set the clock to use the timer mode, again, read the manual.
Here is the instruction manual:
http://www.homedepot.com/catalog/pdfimages/d6/d607d4a8-39b7-4de0-aa94-3fbe86280636.pdf?cm_mmc=seo'altruik'202059606
If you are still having trouble, post back with specific questions, as the instructions are rather tedious.
Dec 08, 2011 | Malibu ML200RT - Low Voltage Power Pack...
How do you set upm model dt 420 electronic timer
Open UPM DT420 manual on following link:
http://waterheatertimer.org/UPM-timers-and-manuals.html#DT420
The manual is longer than allowed for free answer and has important illustrations and options.
Please read the manual in addition to instructions given below.
Copied directly from the manual:
1) Select AUTO using the slide switch
2) Select the desired On-period (2, 4, 6, 8, 10 hours) using the dial switch
3) For continuous Dusk to Dawn operation, Select CONTINUOUS using the dial switch.
Timer turns ON automatically at dusk and turns off according to how you set 1 2 and 3.
If timer does not operate, or if it turns on at odd times, then it is broken.
Note: UPM manuals normally leave out important information, but this particular instruction matches closely with similar products and is probably accurate.
Feb 28, 2011 | UPM Programmable Outdoor Timer
Basic timer will not turn the lights off
Open following link to identify timer, read instructions.
http://waterheatertimer.org/GE-timers-and-manuals.html#15004
I test timers. Some arrive defective.
Also there is a slide switch located on side of timer that has to be set one direction or other.
Move this switch and then manually rotate dial to see how light turns on-off.
Feb 22, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I want to reset the timer for hours of on-off for out water heater but can't figure out how to push the little white teeth in or out. Model is 265-1.
1) Open following link to read about re-circulation systems:
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) Image below show typical FM1 analog timer dial with pins:
Move pins with fingernail or small tool.
To test if pins need to be moved in or out, set pins each direction and manually rotate dial clockwise and listen when pump turns on-off.
How timer operates: clock motor rotates dial continually, pins on dial move lever that turns circuit on-off.
To set current time, manually rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Some timers have a selector switch: move switch to Auto, or Timer, or Timer ON. Again you can manually rotate dial and check which setting is correct.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 14, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
Hardware & Accessories Logo
61 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
