Question about Pioneer Ductless Mini Split Air Conditioner, Heat Pump, 9000 BTU 3/4 Ton, 13 SEER, Cooling, Heating, Dehumidification, Ventilation. Including 13 Foot Installation Kit and Bonus Free Condenser Bracket
Pioneer heat pump not working
Shows error code P1 when turned on in a few minutes ,,and does not work ,,jst flicking error code
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 54 Answers
Error code 22 on thermostat
I see so many problems with these. make sure your thermostat is set to heat. if its hard wired simply turning it to the degrees it shows a bit past, should turn it on.If not check the heat source for any blinking lights which means a malfunction on the heaters it self... If you checked fuse box sometimes to flick the switch to off and back on does the trick to reset it.
Oct 18, 2015 | American Standard Heating & Cooling
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
I am geting a P1 error code
P1 error code is not enough water flow to operate the unit: increase water flow to unit.
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting.
Page 18 of maintenance manual shows how to clean water filter monthly.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Other causes can include faulty sensor, clogged in-line filter, clogged water softener, sediment in pipe, sediment at elbow, bad check valve, water leak, etc.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Rheem Tankless Hot Water Heater...
Why get a P1 error code on my Rheem tankless RTG-64xp?
1) I cannot find Rheem error code P1
http://www.palomatankless.com/owners/homeowner+trouble.lasso
http://www.palomastore.com/paloma_error_codes.html
2) BOSCH does not show P1 either:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
3) Best I could find is that folks with P1 error code report tankless fires for short period, and then turns off.
This implies air, fuel or vent problem, and can be internal, external or combination.
4) P1 appears frequently on control board descriptors, which might imply the error is control board malfunction.
5) Call Rheem 1-800-432-8373, and then add a comment to this thread and let folks know what you discover.
6) I will also call Rheem when time permits, and post what I discover.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 05, 2011 | Rheem Water Heaters
My Pioneer Auto CD Player has an Error 11 & 12 message, plays for a few minutes then the error message shows
the laser eye needs cleaning.....i actually just did mine today, just with a normal cleaning cd...if it doesnt work first time, smear a little nail polish remover on the cleaning disc, it works a treat........error 11 and 12 mean the laser cannot read disc properly......starts and stops depending on how much cleaning is required....
Sep 13, 2009 | Pioneer DEH-1600 CD Player
Code FL1
hi, this generally means a flow error and shows when the heater is looking to heat but there isn't enough pressure running through the heater tube. in this case the thermal overload sounds like it has tripped in the pump.
Jun 06, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Sep 13, 2008 | Danby DDR2506 Dehumidifier
P1 and P2 error codes
E2 = Not draining
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
Pioneer Ductless Mini Split Air Conditioner, Heat Pump, 9000 BTU 3/4 Ton, 13 SEER, Cooling, Heating, Dehumidification, Ventilation. Including 13 Foot Installation Kit and Bonus Free Condenser Bracket Logo
262 people viewed this question
Top Pioneer Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Pioneer Heating and Cooling Expert? Answer questions, earn points and help others
