Question about Kenwood Bm250 Bm256 Bm350 Bm366 Bm450 Bread Maker 8mm Kneading Kneader Paddle
How do I start the bread making process
Forgot the procedure...been kept away for a few years
  • 484 Answers
Put in your ingredients, choose size of loaf, type of bread you want to make then press start and leave alone.
Posted on Nov 14, 2014
Tip
After six years my battery is low, so I took my Tissot Touch back to the shop...
When you need frequent re.Syncronizing of your Touch or after 2-3 year
maybe you need to replace the battery.
you need:
a CR1632 3V Battery (about 2€)
a very tiny screw driver
a very sharp knife
With the knife remove the bottom of yout Tissot, (you do not need to unscrew) it's just a cover to pull up like in this imagedcef0c0d.jpg
Now you can clean with a soft brush & remove the dust.
Use the screw drive to replace the battery,
put back the cover & enjoy
on Aug 29, 2009 | Tissot T-Touch T33759851
We haven't used our Black & Decker B2200 breadmaker for a few years. When we did, liquid and uncooked flour were left at the end of the cooking process. Could this be due to lack of use? If
When your machine started kneading did you notice if the ingredients were actually mixing? Sometimes the drive belts on bread machine break and there is no mixing (the paddle doesn't spin around)
Jan 25, 2013 | Black & Decker Bread Machine
In what order should you add ingredients containing water, sour cream, flour, soda, etc. and yeast? My last bread never mixed and was one big lump. I have had my machine for years and can't locate my...
As long as you start the bread right away and are not using the timer it doesn't make much difference.......as a general rule I always add the yeast last and then push "start"
Apr 03, 2011 | Regal Ware Kitchen Appliances - Others
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
Bread pan pops out during the kneading 2 cycle
I had a similar problem after using the same machine for several years. It worked well for years and then popped off the shaft whenever I had a rather stilll dough. To solve the problem I bent the clips on each side of the bread pan that hold the pan into the machine up and toward the center of the machine. I did not use any tools to do the bending. It solved the problem. The pan no longer jumps up out of the clips and off of the shaft.
Jun 02, 2009 | Breadman TR2200C Ultimate Bread Maker
Bread recipe
Here is a site with many manuals and recipes
http://www.creativehomemaking.com/cooking/bread-machine-manuals.shtml
Hope this Helps
Kurt
Mar 22, 2009 | Kitchen Appliances - Others
Lubricant for bread maker pan mixer shaft
I just cleaned the shaft and put on Silicon. It seems to be working at top speed now. I almost threw the machine away, but itt makes wonderful bread.
Jan 05, 2009 | Kitchen Appliances - Others
Me too! I have to bend the two metal pieces on the sides out before every use - they are pretty flexible, you won't break them. Just bend out and they hold the pan in for a use or two. Not an elegant solution, I admit, but it works.
Dec 31, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2500 BC
See my posts on this problem.
Do not mess up the clips.
Aug 21, 2007 | Breadman TR2200C Ultimate Bread Maker
Kenwood Bm250 Bm256 Bm350 Bm366 Bm450 Bread Maker 8mm Kneading Kneader Paddle Logo
96 people viewed this question
Top Kenwood Kitchen Appliances - Others Experts
ka4iup
ka4iup
ray gallant
Irene Tulloch
Are you a Kenwood Kitchen Appliances - Other Expert? Answer questions, earn points and help others
