Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer was running well, then all of a sudden it stopped spinning. I tried giving it a couple of minutes but it still won't spin. So i turned it off unplugg
Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer was running well, then all of a sudden it stopped spinning. I tried giving it a couple of minutes but it still won't spin. So i turned it off unplugged it and plug it back in and started it, but still no spinning. Everything else is operating but it just won't spin. What could be the best way of fixing it? if there's no spending money then that would be great. i just had to pay to get a new element installed
IF THE DRUM ISNT SPINNING BUT YOU CAN HEAR THE MOTOR YOUR BELT IS BROKEN
Posted on Nov 14, 2014
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
  • 106 Answers
SOURCE: Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Posted on Mar 01, 2009
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
SUPERMAN_B_1
  • 294 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Posted on Apr 06, 2009
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
Posted on Jul 20, 2009
Whirlpool duet sport dryer stopped running after 20 minutes into a 40 minute cycle on hot.
Check for clogged vent. Vents will clog midway and if vented to the outside of a house, there is a plastic cover that usually gets covered with lint that gets wet and dries to a hard mask.
Feb 02, 2017 | Whirlpool Dryers
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
I can't get my whirlpool started?
You might have a problem with the door switch. Try to reset the unit by unplugging it for a couple of minutes. If that does not work then you need to see if the door switch is bad.
Oct 15, 2012 | Whirlpool 8572546 Duet Sport Stacking Kit
I have a Whirlpool Duet dryer, model # WED8300SW2 and the power button will not come on. Can you help?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
heatman101
Oct 11, 2010 | Whirlpool Dryers
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Duet Sport Washer won't spin
dduet front load fills--no wash drains what's wrong a belt?
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
