Question about GE Refrigerators
GE FREEZER ON TOP # GTS22IBMBRWW RUNNING WARM
Ice was building up in the freezer .i was gone for two days came home frig warm freezer defrosted cleaned and unplugged for a day. Plugged it back in both fans running feel cool air, and compressor is very cold to the touch .but freezer is 72' frig 68. Can't find defrost timer, I think it's stuck in defrost, any troubleshooting ideas
  • GE Master
  • 744 Answers
Hello Steve;
My name is Peter. I am a retried field service refrigeration technician.
You are not locked into the unit defrost mode. When a unit goes into defrost every 8-10 hours for 20-30 minutes, your defrost heater activates, and everything shuts down except for the light.
Lets check it out, possibilities:
1.) You may have a bad temperature sensor. You have two temperature sensors. They are both identical, part number WR55X10025. They cost about $11.00. After you cut the sensor wires off you must splice the new sensor in. These are #203 & #605 on the diagram. Sensor #605 is on the freezer right side wall. It is housed between #634 & #632. There is only 1 screw that you have to remove to access the sensor.
Be extremely careful, before replacing unplug the refrigerator. The evaporator coil fins are razor sharp. This sensor must be position exactly where the old sensor was.
For the small cost of these sensors, it may be worth the effort before you purchase a new refrigerator.
UNLESS:
2.) You may have a restriction or a refrigerant leak. You are feeling cool air because, with a restriction, in the back of your freezer where your evaporator cooling coil is, with a restriction you will have ice built-up in the upper right on the cooling coil. With a refrigerant leak, only part of your cooling coil will have a frost pattern.
There are just a few screws holding you freezer back cover. Slide the freezer rack either to the right or left. Lift up on the opposite side to remove. Having removed the cover. Lean the cover against the back. Close the freezer door. Wait 30 minutes, pull the back cover off and check your frost patter.
You will have to copy the last image and paste it so you can better read the image
GE FREEZER ON TOP # GTS22IBMBRWW RUNNING WARM - 25282990-0ixct5jkknl2jbagohl4scxa-3-15.jpg
Posted on Nov 14, 2014
mikedurland
  • 481 Answers
SOURCE: warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 10, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
rpbuice
  • 161 Answers
SOURCE: GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Posted on Dec 17, 2008
lenwest
  • 150 Answers
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
jmgldsmth
  • 1889 Answers
SOURCE: Freezer very cold fridge warm.
the freezer circulates air through the refrigerator by using a fan every 24 hours the defrost timer comes on the compressor goes off and, the machine defrosts if your mullion defrost heaters are getting hot
and, staying hot you have miss-wired your defrost timer
Posted on May 25, 2009
I have a GE profile side by side refriderator. The freezer is working(temp is below zero on coldest setting, but the refridge is warm, ranging from 36 -59 degrees depending on the shelf. (this is on the...
the ice is caused from the frozen drain in the back. the cold coil is also frosen / this stopes the air to the fresh food .. so defrost the freezer and ck the heater and defrost termator . . you may also need the main control that has the defrost timer on it . located on the back of frig.. hope this helps . mm
Jul 11, 2011 | GE Refrigerators
Help my frig is dying! The freezer compartment is working fine-but the frig compatment is nit colloing at all! What is wrong?
If the freezer is working that is a good sign. Here are what might be the problems; 1) Ice build up in the freezer will block air flow to the refrigerator and thus causing it to get warm and stay warm. If you observed a build up of ice in the freezer, it means that your defrost heater and/or your defrost thermostat is bad. In any case, replace both.
2) The evaporator fan plays an important role in circulating cold air in both freezer and refrigerator compartment. Listen for the evaporator fan and make sure that is running. If you can hear it, it has gone bad and will have to be replaced.
3) if any of the above applies, the lower or upper air dampers may be obstructed. Check and make sure that they are open.
4) Too much food or stuff in the freezer may also be the culprit. If there is too much stuff in the freezer, you might want to remove some them to make way for air to flow in the refrigerator compartment.
I hope this will help solve the problem. Do not forget "Feedback"
Jacques
Mar 24, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Warm frig cold freezer
is the fan running in the freezer? most likely the evaporator coil is frozen over. is there frost build-up on back freezer wall. what is the model #? could be the defrost timer, heater element or the defrost terminator.
Oct 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Frig too warm, freezer too cold
if there is ice build up you have a defrost problem. either the heater bimetal thermostat timer or evap fan could be bad. you could also have a stopped up drain. if the coils get too much ice build up the air wont beable to travel through them and the bad air flow will cause the fridge to become warmer
Sep 16, 2009 | Frigidaire FRT8S6EMB Top Freezer...
GE frig/freezer side by side about 5 yrs
Bad defrost timer, most likely. It is not defrosting the evaporator, and therefore, no air can be passed over it. Hope this helps
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm frig and cold freezer
usualy a defrost problem check for ice on back wall in freezer thats most common problem check for ice on wall in freezer ice build up is due to defrost system failure
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge not cooling
is the freezer fan running?is there any frost in the freezer?can you pull the frig. out and see how hot it is?is the comp. fan running?is the comp. clicking on and off,let me know what you find-mike
Nov 07, 2008 | GE Refrigerators
Refrigerator on the fritz
The defroster is not working. Ice build up prevents cold air from the freezer chest from blowing into the lower part.
The way the defroster works is this: There is a defrost timer, probably found under the refrigerator at the front, that turns on the defroster three times per day or so. That turns on a heater nested among the freezer coils. It keeps heating until the defrost thermostat gets warm; then it quits defrosting.
I think your defrost timer doesn't turn. You can turn it with a screw driver till you hear a click. Now your ice compartment should be defrosting. With ice buildup it may need lots and lots of defrosting. You might not get cooling back into the lower part for awhile, till the ice buildup melts.
By the preceding, you should know if the defrost timer needs replacing.
If you should need to manually defrost the freezer coils, they are, I think, under the floor of the freezer. To defrost them, I'm told, a hair drier works better than boiling water. The defrost thermostat is in there too, a one inch unit with two wires. It should have no continuity warm, closed circuit frozen. If it has open circuit frozen, that would be your problem.
Jun 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Duct from freezer to frig is blocked with ice, frig warm
give the unit a full defrost then unblock the drain hole. it sounds like the tiny defrost heater element may not be working and is therefore causing excess frost to build up on the freezer evaporator. also check door seals are not holled anywhere.
May 31, 2007 | Hotpoint HTR15BBMRWW / HTR15BBMRAA /...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
