Question about 2002 Chrysler Concorde - LXi, with climate sensor, with alarm sensor - Ltd. Edition Dashboard Cover
My engine revs but doesn't accelerate right away, then jumps hard when it does finally go... What's wrong with my car?
This happens no matter how long I let my car warm up before driving. It does this in reverse, as well as drive. I've also tried shifting through the gears manually and it does the same thing. It does it worse when I go around sharp curves or if I try to pull into a parking spot. I have tried babying it into gear and forcing it and neither helps.
    Master:
  • 366 Answers
Get clutch tested ?
Posted on Nov 29, 2014
Slipping accelerating
Most of the time when a transmission slips
& you notice it,it has been doing so for some
time & it will need to be rebuilt,90% of the time
You have no info here in your question,not even
a vehicle or trans model
Can't help with the clicking
Jul 26, 2013 | Cars & Trucks
1993 Mustang 2.3L Trouhble(again); It's slugish at accelerating from a stop(some times falling on its face and dieing), jerks at highspeeds when trying to accelerate, and has hard starts. Any help
All the above problems were happening to my truck, and the engine light never did come on. Finally changed the O2 sensor, and it runs like new again.
Mar 30, 2013 | Cars & Trucks
Engine losing power and jumping when accelerating
when was the last good tune up done? fuel filter changed? air cleaner? check emissions vacuum system for leaks..repost findings
Feb 10, 2013 | Cars & Trucks
What is wrong when you turn the key to start and the radio and all the instruments turn on but the starter doesn't click and the engine doesn't turn on even after trying to jump start it
Dead battery
Dangerous practice to try & jump a dead battery
The battery cables could be loose at either end or corroded internally
Most likely the battery is worn out, if original to car
since it was new, or the starter solenoid is worn
You do not want to jump any vehicle made after the
year 2000 or your asking for possible problems with
todays electronics.
You need a good battery that has been tested & fully
charged, then only jump with a jump pack,not another car
Jan 21, 2013 | 2008 Buick Lucerne
1998 VW Jetta Throttole Issue
you have an adjustable throttle cable top & backside of motor.. very easy to adjust back down... my jetty stayed idled too low & would randomly rev until cleaned entire intake & adjusted pin on cable... check engine light went out and it auto cleared code almost immediately
Aug 04, 2012 | 1998 Volkswagen Jetta
My speedometer jumps from 20-40mph when Im stopped. Also, the blinkers blink rapidly when this happens. If i turn the lights on, it revs. Doesn't do it all the time.
I would look for a broken ground wire..If its a ground wire it should be one of the big ones..Theres one from the firewall to the block..If any body work has been done or major engine work ,,sometimes the grounds are left off..If all looks good it may be in the cluster or the GEM module..
May 06, 2012 | 2002 Ford Taurus
When i am driving useing the clutch my car doesn't get up to speed
possible clutch wear , if the clutch is worn, adjusted wrong, or slipping, this same thing will happen, depending on how many miles are on your vehicle, it may be time to replace the clutch ., you don't state if the motor seems to be running smoothly ,, or the same as it was prior to this problem,, if it seems ok, its time for a new clutch
Sep 21, 2011 | Ford Focus Cars & Trucks
My Ford Windstar 1999 doesn't drive forward or
Has the transmission ever had any services done? Its possible it has just gone out. There are clutches and bands inside and without proper service they will go out.
Sep 02, 2011 | 1999 Ford Windstar
My Hyundai Sonata 2001 4 cynlinder doesn't run well after stopping at a stoplight. When I accelerate it takes a while for the car to go up to speed right away. It doesn't just take off. It...
You have to separate engine issues, from transaxle
slippage
Could you tell us more info & detail
I assume it is automatic & the trans is gone,unless
you say it shifts fine & has serious engine problems
& no one so far has been able to resolve
What is the time frame here on all vehicle issues?
Aug 04, 2011 | Hyundai Sonata Cars & Trucks
2001 Century turns off while in motion. No lights display, so I have no warning, but realize I'm not getting any acceleration as my first clue. It's happened at varying speeds and when the car is...
Doesn't want to accellarate while driving. In neutral it will rev up to a certain point but not full throtle. I put factory recommended uridium plugs (6) in, didn't help. Is it a catalitic converter problem or something else? thanks
Jun 21, 2011 | 2001 Buick Century
2002 Chrysler Concorde - LXi, with climate sensor, with alarm sensor - Ltd. Edition Dashboard Cover Logo
Top DashMat Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
daf62757
Level 1 Expert
Are you a DashMat Vehicle Part and Accessory Expert? Answer questions, earn points and help others
