Question about Matfer Imperia R 220 Manual Pasta Machine 073175
I have a problem with my Imperia Pasta Machine R220. When I initially try to put pasta dough through the rollers they are not able to roll it through. If there is more than a slight amount of resista
I have a problem with my Imperia Pasta Machine R220. When I initially try to put pasta dough through the rollers they are not able to roll it through. If there is more than a slight amount of resistance from the dough the rollers will not spin as though some gears have been stripped. I would really appreciate a solution to my dilemma. Thanks.
How do i clean the motorized dies on my imperia pasta machine
The machine comes apart easily. Once you take it apart, turn the machine upside down and see if the dried dough is visible in the vent holes. If it is pick it out with a toothpick, if not you will have to let them be.
Apr 09, 2013 | Imperia "Pasta Machine Rm220 Motorized:...
How to clean the dryed pasta from Imperia Electric Resturant RM220 Pasta Machine Cylinders
I use a toothpick and toothbrush which is gentle and will not damage the plates and you can poke the toothpick through the holes.
Mar 15, 2013 | Imperia "Pasta Machine Rm220 Motorized:...
Just bought Imperia RM220 that won't start at all.. WHat's wrong with that?
Just attach the pasta machine to your countertop, table or cutting board with the clamp.  Put the crank in the hole.  The pasta goes inbetween the rollers of course and turn the crank.  Start with the rollers furthest apart or the biggest number and roll the dough twice on each number.  There are videos to watch on my website:
http://noodlemakermachine.com/wp-admin/post.php?post=16&action=edit
 Good luck with that!
Feb 15, 2011 | Imperia pasta machine - Original Made in...
I cant seem to get the 150 to pull the pasta through the thickest setting. I am pretty sure that my pasta is thin enough to start.
The dough needs to be just right. It is sometimes difficult to get it started and the first couple of times through the machine the dough will be uneven and maybe break apart. Just put it through again and as the gluten develops from the handling, it will smooth out and be more workable.
Good luck. If you would like to see a video, try this link.
Feb 15, 2011 | Imperia CUCI 150 Fresh Home Pasta Machine
Pasta Machine turning pasta sheets out with lots of holes? What are we doing wrong?
Start with the rollers farthest apart and when you first start rolling the dough will be uneven and have a few hole. But as you roll the dough over and over, it will be smooth with no holes in nice flat sheets. Rollthe dough twice on each setting, starting with the biggest number and rolling down to the smallest number for very thin sheets of pasta. Good luck. I have a recipe and videos on my website at http://noodlemakermachine,com.
Jan 16, 2011 | KitchenAid Kitchen Aid Pasta Maker...
Wear can I find a parts break down for an Imperia R220 Pasta Machine?
http://www.fantes.com/manuals/imperia-restaurant-pasta-maker-manual.pdf Internal parts are at the end, and all in Italian. I haven't had any luck finding someone who sold internal parts for this machine, but maybe this site will help.
Feb 23, 2010 | Kitchen Appliances - Others
Why my dough is tearing when i try to make ravioili?
You have to let the dough rest about 30 min. to 1 hour before passing the pasta in the roller. Also if you put some flour on both side of your pasta for the first passing through the machine it works well.
Jul 21, 2009 | CucinaPro Cucina Pro 150-25 Pasta Ravioli...
Pasta machine with no instructions
Check out this link, its all there. I use a food processor instead of hand mixing, its faster.
http://www.fantes.com/imperia.html
Have fun!
Mar 24, 2008 | La Pavoni Imperia Pasta Maker-Maunal (for...
Matfer Imperia R 220 Manual Pasta Machine 073175 Logo
101 people viewed this question
Top Matfer Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Matfer Kitchen Appliances - Other Expert? Answer questions, earn points and help others
