What is wrong with my you tube do not open? - Computers & Internet
    Sergeant:
  • 209 Answers
There was an upgrade not long ago. You will need to download the latest version of YouTube
Posted on Nov 23, 2014
Why does my heater not work in my car the center console heater works but my dash heat does not but the buttons light up and you can hear it but doesnt blow out what is wrong ? i have am 1994 cadilac...
Behind the dash are tubes that carry the hot air to the different vents. When you select dash output, the buttons send an electric signal to motors to open flaps in these tubes. The buttons are lit, so they have sent the signal, it hasnt reached the motors or the motors are not turning the flaps, so the air does not get routed to the dash. That is what is wrong
Dec 20, 2013 | 1994 Cadillac Eldorado
Blackberry 9790 have screen display gone wrong
Hy Bhavika, dont worry, just open device and unplug the LCD from board and plug again. it will solve the problem, this many times happen when device fall down.if my solution was helpful, rate the answer.Best of luck. also see on you tube how to open device and close.
Jun 28, 2012 | Cell Phones
How to use a metal pendant w/fillable tube?
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 26, 2012 | Cars & Trucks
2000 Ford Focus...DTC code PO455
code PO455
EVAP Control System Large Leak Detected
Possible Causes:
Aftermarket EVAP hardware non-conforming to specifications Canister vent (CV) solenoid stuck open EVAP canister purge valve stuck closed, or canister damaged EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube disconnected or cracked, or canister is damaged Fuel filler cap missing, loose (not tightened) or the wrong part Loose fuel vapor hose/tube connections to EVAP components Purge sensor or FTP sensor is out of calibration or has failed I would say that your gas cap is a good place to start.
Apr 25, 2012 | 2000 Ford Focus
Describe your Problemcheck engine light codes p0457 p0455
Trouble code P0455-EVAP Control System Large Leak Detected
Trouble Code Conditions:
ECT sensor less than 90°F at startup, engine running, and the PCM detected several small fuel vapor leaks or a large leak in the system.
Possible Causes:
  • Aftermarket EVAP hardware non-conforming to specifications
  • Canister vent (CV) solenoid stuck open
  • EVAP canister purge valve stuck closed, or canister damaged
  • EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube disconnected or cracked, or canister is damaged
  • Fuel filler cap missing, loose (not tightened) or the wrong part
  • Loose fuel vapor hose/tube connections to EVAP components
  • Purge sensor or FTP sensor is out of calibration or has failed
Jan 22, 2011 | 2006 Ford Explorer
Want to watch young and the restless
Hi, You can Open you tube in Pakistan by browsing you tube from www.dldn.net. First open www.dldn.net and browse you tube through this site.
May 21, 2010 | YouTube Videos
My Meebas is fully grown but tube won't open....what are we doing wrong??
Apparently meebas need a little help to pop open a lot. I found out that if you run a large safety pin under the top of the tube where the meeba is supposed to come out & pull the lid upward some - the lid will pop off. Hooray...the crying has ended. Perhaps this speaks to evolution needing the help of a higher being.
Dec 25, 2009 | Mattel My Meebas Interactive Pet
What is he code 455 for a 2006 hyundai sonata means
CODE PO455 EVAPORATIVE EMISSION SYSTEM LARGE LEAK DETECTED.POSSIBLE CAUSES CANISTER VENT SOLENOID MAY BE STUCK IN OPEN POSITION / EVAP CANISTER TUBE EVAP CANISTER PURGE OUTLET TUBE OR EVAP RETURN TUBE DISCONNECTED OR CRACKED OR CANISTER IS DAMAGED / EVAP CANISTER PURGE VALVE STUCK CLOSED OR CANISTER DAMAGED / FUEL FILLER CAP MISSING LOOSE NOT TIGHT OR THE WRONG PART / FUEL VAPOR HOSES TUBES BLOCKED OR RESTRICED OR FUEL VAPOR CONTROL VALVE TUBE OR FUEL VAPOR VENT VALVE ASSEMBLY BLOCKED /FUEL TANK PRESSURE SENSOR HAS FAILED MECHANICAL FAULT /FUEL TANK CONTROL VALVE IS CONTAMINATED DAMAGED OR HAS FAILED.
Oct 21, 2009 | 2006 Hyundai Sonata
I have a 3 year old kenmore fridge withfreezer on the bottom and water in the door. The water only trickles out even ater replacing the filter. What's wrong?
It sounds like the water tap from the source is clogged, or the vinyl tubing running from the water source is crimped somewhere. I would check the tap first to make sure the valve is not clogged. You close the valve clockwise ,then remove the tubing. Have a bucket handy. Open the valve counterclockwise a little at a time until water started to drip. Place the bucket under the valve to catch the water. Open the valve a little more and let the water go into the bucket. Do this until you are satisfied that the tap valve is not clogged. If this does not solve the problem then check the tubing to see if you have crimps in the line. Then close the tap valve clockwise down tight. remove the tubing from behind the frig and if you have enough slack, take that end to the tap valve and the bucket, place the frig end of the tubing in the bucket, open the tap valve until you are satisfied the flow is nomal., close the tap avel and hookup the frig end. Open the tap valve an the test the water dispenser for flow.
Jul 16, 2009 | Kenmore Refrigerators
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
