Question about Roland EGX-600 Benchtop Engraving Machine Pro Series
Just bought a new Roland EGX-600 Engraver but machine will not start properly. When I hit "Enter" it just gives a "Just a moment please" message but will not initialize beyond that.
Cutter not rotating when set to, correct fittings in place just judders and the engrave light flashes
Is the spindle motor OK? Try turning it with your fingers (POWER OFF). Also try taking the cutter out and rotating the empty collet (POWER ON) with your fingers.
The spindle motor may be dead.
Sep 03, 2013 | Roland EGX-30A Desktop Engraver
Alphaplugins engraver II serial
I want Serial Number for "engraver ii" Someone whose knows the serial number,... Please Give Me !!!
Apr 01, 2013 | AlphaPlugins Engraver II for Photoshop
Roland VS 2480 v2 - working on album and received error message "load project please wait" since last night. have tried turning machine off and on and unplugging it. still same message.
Hi, have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES.
If the factory reset does not fix the problem i think you have to format the disk because it has a fragmented disk .......
Dec 12, 2010 | Roland Vs2400CD Digital Workstation W/CD...
I just started using this engraver today. I got up to give my hand a rest and when i came back i engraved one item and it stopped working after that. What could have happened?
If it's a brand new Dremel return it for a new one. If not it may have overheated. Let it sit for a few hours and try again. Always be sure the vents are free from any blockage as this can cause the problem.
Jan 26, 2010 | Dremel 290 - 01 Engraver
Please i have a roland pnc - 2300 to engrave gold peices
please i have a roland pnc - 2300 to engrave pices of gold the program software i use is called ( ats graphic suite version 1.02) when i want to start engrave i click file engrave and give the order but the printer didn't begin the engrave there was inside the folder printers a file called cut script i didn't find it and the roland didn't start engrave can you help me my email is flexoart1@gmail.com
Regards Saleem Tahir
Mar 11, 2009 | Microsoft Computers & Internet
Error loading c:programe 1 mywebs 1bar 2 bin m3plugin.dll
Click start, then click run
In the box, type msconfig then hit enter.
Go to the startup tab, and find the line that displays the path contained in the error message then uncheck it.
Click apply. Click yes to restart your computer.
Your computer will restart without that message. When the system configuration utility box comes up, check the box then click okay. It's done ;c)
Thanks and please take a moment to rate as fixya.
Nov 15, 2008 | Intel Motherboard
Roland EGX-600 Benchtop Engraving Machine Pro Series Logo
77 people viewed this question
Top Roland Computers & Internet Experts
Darren  Means
Darren Means
Stu Morris K
Gil Shultz
Are you a Roland Computer and Internet Expert? Answer questions, earn points and help others
