Question about OEM 1998 Pontiac Grand AM Radio / CD Player wmz50072e AM-mono-FM-stereo-CD player-equalizer "UP3" Houston, Texas
<!-- from fixya rte -->What causes the check engine light - OEM 1998 Pontiac Grand AM Radio / CD Player wmz50072e AM-mono-FM-stereo-CD player-equalizer "UP3" Houston, Texas
We have had check engine lights on all vehicle for 35 years
So check for OBD Codes,Google them & then diagnose those
codes to find a problem
Posted on Nov 14, 2014
My Holden barina won't start and check engine light is flashing
Check Engine Light On - Auto Diagnosis Repair Help
www.aa1car.com/library/mil.htm
The Check Engine Light (which is actually the Malfunction Indicator Lamp or ... you can assume the fault that is causing the Check Engine Light to come on is probably minor and won't hinder your ability to continue driving. ... When the ignition is turned on (don't start the engine yet), the tool will .... flashing check engine light ...
What Causes the Check Engine Light to Come on in a Car?
www.wisegeek.com/what-causes-the-check-engine-light-to-come-on-in-a...
Nov 7, 2015 - When the check engine light comes on, take the car to a reputable mechanic .... I went to go home. the check engine light was blinking and it won't start. ... I looked in my manual book for 2001 holden barina car to see what the ...
Car cranks but won't start, Check Engine light blinking ...
www.evolutionm.net/...engine.../424408-car-cranks-but-won-t-start-chec...
Jun 1, 2009 - I tried to turn it back on but it would only crank and not start, the check engine light is also being really weird, it's blinking on and off pretty quick.Missing: barina
Check engine light flashing car won't start - RX8Club.com
Dec 09, 2015 | Holden Cars & Trucks
Malfunction light on. rapping sound in engine when stepping on or letting off gas.
Oil filter caused check engine light? - Kia Forte Forum : Sedan ...
www.forteforums.com/.../4315-oil-filter-caused-check-engine-light.html
Dec 16, 2010 - 14 posts - ‎7 authors
I'll start out by saying I recently bought my 2010 Kia Forte Sedan with 20000 miles already on it. The other day the check engine light came on ... Malfunction indicator light!! Please Help!
Aug 1, 2013
KIA Check Engine Light (CEL) Codes
May 19, 2012
Malfunction Light ON!
May 19, 2012
Check Engine Light + P200A code on new 2011 SX
Jun 7, 2011
More results from www.forteforums.com
Nov 15, 2015 | 2010 Kia Forte
Trac off, check engine light and vsc lights on on a 2006 lexus es330
Hello, the reason for the vsc light to turn on is that the check engine light came on first causing the vsc system to become disabled, this is normal, once the cause of the check engine light is fixed the other lights will turn off. You'll need to find out the diagnostic codes that caused the check engine light to turn on first, most auto parts stores like autozone, pep boys, o reilly can help you with getting those codes from the computer and they do this for free in most US states, when you have the code numbers you can reply if necessary and I can advise as to what should be done.
Mar 16, 2014 | 2004 Lexus ES 330
Engine check light on 2001 Toyota Highlander is on. What's cause(s) of it?
CHECK ENGINE LIGHT ON YOU NEED TO GO TO ANY AUTO PARTS STORES THEY WILL CODE SCAN VECHICLE FREE AND SEE WHAT CAUSE CHECK ENGINE TO TURN ON.WHEN CHECK ENGINE LIGHT TURN ON YOUR PCM HAS SPOT PROBLEM IN THE ENGINE CONTROL SYSTEM,COULD HAVE FAULTY SENSOR OR CYLINDER MISFIRE.
Oct 13, 2011 | 2001 Toyota Highlander
2005 Chevy Impala LS. Will a bad upper intake cause an engine light to come on. I've been told I need a new Upper intake but currently have no engine light on.
the check engine light comes on when there is an issue with a sensor/sending unit/system/or something the pcm controls. The check engine light does not come on when there is a mechanical issue such as a bad lower intake gasket.
There are times when a mechanical problem can cause a sensor to read incorrectly and cause the check engine light to come on.
Jul 30, 2011 | 2005 Chevrolet Impala
The orange light came on today in my 2004 chrysler pacifica. What does tht light mean?? Is it the engine light?
Without seeing a picture I couldn't say for sure, but typically the check engine light is orange and shaped like a motor. There is no way for you to know off hand what the problem is that caused it to light up, I recommend you go to your local Autozone, they can plug into the computer and check the cause of the fault for free.
May 18, 2011 | 2004 Chrysler Pacifica
I HAVE A PO125 AND PO650 FAILURE CODE
P0125 - Insufficient Coolant Temperature for Closed Loop Fuel Control Possible causes - Harness or connectors (The sensor circuit is open or shorted.)
- Engine coolant temperature sensor may be faulty
- Thermostat may be fault (most common cause)
P0650 - Malfunction Indicator Lamp Control Circuit Malfunction (Check Engine light)
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
Possible causes - Harness or connectors for the MIL (Check Engine Light) circuit is open or shorted
- MIL bulb may be faulty
- Faulty ECM
Mar 02, 2011 | 2000 Oldsmobile Alero
Engine will not stay idling
Dirty throttle plates and idle speed control motor can cause stalling without setting check engine light. If your check engine light is on you will have to get the code out and continue from there. Vacuum leaks will also cause engine to stall but usley set check engine light.
Dec 21, 2010 | 2001 Chevrolet Suburban
My ford focus' check engine light just came on on the way home from work and is flashing periodically car seems to be running ok so far can you help
flashing check engine lights mean that there is a critical failer that could cause severe damage. they should not be taken lightly. a missfire can cause the light to flash. the best thing to do is take car to a shop or an auto parts store to get the check engine light read. check engine lights dont always tell you exactly what is rong, but this will give a good direction to start in. a check engine code would be helpfull in diagnoseing the cars problem.
Apr 23, 2010 | 2004 Ford Focus
''Check Engine Soon'' light Stays On.
Must have engine computer scanned to get codes and determine cause of check engine light. Low tire light probably needs reset. Open passenger door and remove panel on side of dash. Reset switch should be located in that compartment.
Mar 31, 2009 | 2001 Buick Century
OEM 1998 Pontiac Grand AM Radio / CD Player wmz50072e AM-mono-FM-stereo-CD player-equalizer "UP3" Houston, Texas Logo
78 people viewed this question
Top OEM Audio Players & Recorders Experts
Coss
John
John
Are you an OEM Audio Player and Recorder Expert? Answer questions, earn points and help others
