Question about Radio Communications
Zackery t will not key up or modgulate what could be the problem
When ptt.needle falls to zero and will not swing forward
    Master:
  • 742 Answers
Um it could be broken, most likely user error
Posted on Nov 15, 2014
1991 Volvo 940SE Speedo Problem
The symptoms you describe point to a loose or cracked speedometer cable. The cable likely needs to be replaced.
Feb 15, 2014 | Cars & Trucks
Icom 756 when i press ptt the signal needle goes to zero
Hi Patrick,
You've got a great brand there.
The best info available on the web is by joining yahoo group specific to your radio Make/Model, the techs there will need as much info as you can throw at them so they can solve it quickly for you, plus you can download manuals, schematics and other goodies for your radio, and all of this costs $0.00 = FREE.
I know, I am a member and they are the best in the business
I hope you found this answer helpful.
Cheers,
Peter
Dec 27, 2012 | Radio Communications
Whirlpool capicator 189-227MFD how can I tell if its good
To check the capacitor disconnect the wires from it and use a meter set to ohms..if using a digital meter set it to a high ohms setting,place one meter lead on each wire terminal and the display should constantly be in motion in as much the display will go from 1000 omhs to 20,000 ohms and just continue that if the cap. is good and the display will stay the same and never change if the cap. is bad
On a analog meter the needle will swing to zero and rapidly go back if the cap. is good and will swing to zero ohms and stay there and the needle is will not drop if the capacitor is bad.
GENE
Sep 13, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
My Elna SU will only do straight stitching it will not zig zag
Feb 02, 2011 | Elna Quilter's Dream 6003Q
Needle hits
Does not matter what machine you have from a 50's straight stitch to a newer model right out of the box. If your needle is hitting you are out of time. It needs to be reset and on that I can not help you as it is mechancal on the underside. What the needle is hitting is the bobbin arm.
When the bobbin arm swings around it picks up the top thread and loops it over the bobbon thread then releases the threads together for the loops and swings again for the next thread. When you hear the needle hit it is hitting this swing arm. That needs to be adjusted and that is called timing.
Open the bobbin case and turn the needle down by hand. You will see the needle as it goes through the throught plate down the catch the bobbon thread. You will see it hit the arm.
This needs to be backed off or set forward. Takes a trained person as I have never been able to do it myself. This happens when you sew to thick of a fabric, or go over several seams from light to thick. Or is you are pulling the fabric. If you head a CLUNK when it started then that is what I think it is.
Dec 18, 2010 | Euro-Pro Shark 9110 Sewing Machine
Pegging aftermarket tach. SunPro CP2011 installed in 1975 Chevelle. 350/350 Stock HEI. Needle at 9800 if engine running or not. Disconnect pwr wire and needle falls forward to dials. Not back to zero....
had one break like that! my buddy did the same thing! never figured out what it really was but it came down to it was just pushed past it's last leg. not sure if this is you case i would check the signal wire that goes into the engine bay! what ever you have it hook to like the coil etc... if that is fine i would say it is time for a new one or a warranty! good luck
Sep 18, 2009 | Chevrolet Malibu Classic Cars & Trucks
I need instructional manual for tiger wood 08 pc dvd
Tiger Woods PGA Tour 08 (IBM PC Compatible) Instructions:
COMPLETE CONTROLS
GENERAL KEYBOARD CONTROLS
Alt Key = open pop-up menu
Control Key + M Key = return to main menu
Control Key + K Key = view scorecard
Control Key + L Key = view leaderboard
Control Key + O Key = options screen
Control Key + B Key = view caddie book
Control Key + S Key = save game
Left Arrow or Right Arrow Key = aim left or right
> or < Key or Mouse Wheel = select next club
[ or ] Key = select next shot type
Esc Key = skip ball flight, cancel shot
T Key = toggle trueswing analyzer on or off
M Key = take a mulligan (if enabled)
/ Key = bring up putter
P Key = enage practice swing (once to take a swing, again to step up and address yout ball)
CAMERA CONTROLS
W, S, A, or D Key = move camera forward, backward, left or right
F or V Key = move camera up or down
- or + Key = slow or speed up camera movement
1 Key = swing view
2 Key = ball-drop view
3 Key = blimp view
4 Key = green reading view
5 Key = ball cam forward to green
6 Key = low camera to flag
7 Key = tv tower tee box view
8 Key = tv tower greenside view
9 Key = side profile swing view
0 Key = opponent view
Control Key + E Key = camera editor
E Key = shot target camera
G Key = toggle grid on or off
O Key = toggle overhead map on or off
ONLINE GAMES
Enter Key = chat
GAMEPAD SWING CONTROLS
SETTING UP A SHOT
D-Pad = move targeting mark
5 Button (Hold) + Left or Right Analog Stick = control free camera
9 Button = watch the hole fly-by overview
10 Button = preview club yardage
6 Button = switch clubs
4 Button = change camera view
1 Button = select shot type
3 Button = zoom to targeted landing spot
2 Button = start swing
SWINGING
2 or A Button + Left or Right Analog Stick Down = begin backswing
Left or Right Analog Stick Up = downswing
Left or Right Analog Stick Back Diagonally + Left or Right Analog Stick Up = draw or fade the shot
PUTTING
Left or Right Analog Stick Up and Down = putting
TRUESWING
Mouse Back = backswing
Mouse Forward = downswing, follow-through
Esc Key of Left Mouse Button = interrupt a swing
Jan 01, 2009 | Electronic Arts Tiger Woods PGA Tour 08 ...
I can hear people talking, but they can't hear me, or they say I sound like an alien
Check to see if the meter needle is swinging backwards when you key up. If it does your final may be bad. If the needle goes forward and others say they see your keying up but no sound your audio chip may be bad; especially if you have tried so many mics and antennas. If your radio has a swr warning light and it comes on this could extremely limit your range and others may not hear you and contiued use will damage your radio. Good luck!!!
Jul 26, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
37 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
