Question about Marantz Audio Players & Recorders
MY AUTO AND CUE DOES NOT WORK
I HAVE TO MANUALY LIFT NEEDLE TO PLAY
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Marantz Master
  • 924 Answers
It can be anything mechanical. It would be impossible to narrow it down with only the information provided. If you need more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 28, 2014
Why won't our arm on our record player advance to play record on auto control? Lifts, moves back and returns to original position.
Try adjusting the counterweight on the back. Average weight setting is 1 gram. most high end RPs have it and it's a 'turn clockwise to increase' deal.
If it's a cheapo, there may be something interfering with the arm. possible a spiderweb inside! or??
Aug 17, 2014 | Audio Players & Recorders
I have a Crosley CR49 turntable and the tonearm seems to be misaligned. I lift the cue lever and place the tonearm where I want it to land on the record, but when I lower the cue lever the tonearm moves...
that situation is possible that it is bent a little. make sure your table is level when using it and check the weight in the back to see if its too far out leaving the tone are to bounce of drift easily. you can manually put the needle down in the meantime.
Sep 22, 2012 | Audio Players & Recorders
I have a Garrard DD75 direct drive turntable. The cuing mechanism will not function.
Every answer here is wrong. Just plain wrong. It's electronic cueing via solenoid control. There are no cams. levers, or any sort of automation, except for the auto lift on the lead out grove. Voltages to the solenoid must be checked. Capacitors that frequently go on these models must also be checked. If you can live without cueing, disconnect the cueing cable (much like a bicycle brake cable) and your cueing will set to off until you can sort it out.
Jul 21, 2012 | Audio Players & Recorders
Where is the button/knob set up to play single song verses continuos songs from a cd on Pioneer cdj mk..
The button you need is the Auto Cue button, which is to the left of the top display. Press and hold to turn auto cue off, which puts the player into continuous mode. This button is also the Time Mode button.
Hope this helps
Jaye
Sep 17, 2011 | Pioneer CDJ-1000 CD Player
I have a Pioneer PL-740 turntable that works extremely well, except there is zero damping when either lifting or dropping (and I mean dropping) the needle. I know there is generally a hydraulic oil that...
most turntables actually only dampen during automatic play and return (eject) not when manually manipulating the needle. Better turntables will have a counterweight at the back of the arm behind the pivot point, but that is to decrease wear on the vinyl and increase needle life and audio fidelity in the higher end.
Some turntables have a lifter arm that is dampened, but if your player doesn't have such a mechanism, or if it has one and you choose to manually manipulate the needle without it's usage, there is no dampening.
The fix unfortunately is to buy a turntable with a dampened lifter arm, and to use the arm when lifting and lowering the needle.
Mar 23, 2011 | Pioneer Audio Players & Recorders
The wires connecting the play stop & cue have come loose on my optimus LAB 1100. I need a diagram to show me where to hook them up PLEASE!!!
The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own. http://www.youtube.com/watch?v=PS6g9rQRF9M&feature=mfu_in_order&list=UL
Jan 24, 2011 | Audio Players & Recorders
After sitting unused for many years, I just
Hi, Does the arm have a lever to lift the arm up, also called a cue. I had an arm where it did exactly the same thing and found it to be the lifting device. What turntable is it you have?
May 12, 2010 | Audio Players & Recorders
Cant cue up cd, it just starts playing when inserted
Hey,
no need to worry, there may be problem with micro switch.
Micro switch is that when u press cue there is a another micro switch just bottom of the cue button. I think micro switch needs to be replace and all done.
thx,
djajay
Feb 18, 2010 | Pioneer CDJ-800 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
49 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
