Question about Car Audio & Video
Whats the best way to hook up 2 6x9s & ;1 15 inc sub to xm-zr604amp
  • 637 Answers
The two 6x9
Posted on Nov 24, 2014
simplemitch
  • 752 Answers
SOURCE: protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
Posted on Sep 10, 2007
  • 631 Answers
SOURCE: sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Posted on Oct 12, 2007
jdrrwoods
  • 82 Answers
SOURCE: wiring my subs to my amp
bridge it and rear channel if you need to know how to bridge let me know
Posted on Feb 09, 2008
  • 56 Answers
SOURCE: can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Posted on Feb 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: How to install Sony Xplod XM-1652Z Car Audio Amplifier
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 24, 2009
XM-2002GTW Car Amp: i have 2 dual 2-ohms solobaric speakers and im try...
I researched your amp and it looks like its not even 2 ohm stable :( the problem with these companies is they lable there amps 1200 watts MAX, that means they tested the amp in a perfect enviroment and the amp fried somewhere in the ball park of 1200 watts, your best bet is to save your money and buy a nicer amp that is two or one ohm stable... that being said the best way to wire your subs is in series
May 17, 2010 | Sony XM-2002GTW Car Amp
Can a 1000 watt amp run 800 rms subs and best wiring option
Feb 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a Pyle PLD3MU head unit and a sony XM-ZR1252 amp (2 channel) and the car has 2 door speakers, 2 rear deck speakers, and 2 12" subs. What is the best configuration to hook this up?
Run your 12" subs off the amp make sure to Xover for bass only.
Try running the 4 speakers direct to the stereo may not be enough power, Might have to invest in another amp and speaker upgrade to get it sounding just right.
But its a place to start.
Jan 07, 2009 | Pyle PLDVIN7 Car DVD Player
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Protection light
Sep 10, 2007 | Sony XM-2002GTR Car Audio Amplifier
Amp shuts off when music turned up
try adding a capacitor to feed the amp. these are large in capacity (farads)and dims (about 6' x3' dia.)...what wire size are you using?
May 30, 2007 | Sony XM-2002GTR Car Audio Amplifier
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
