Question about Fender Passport 150 PRO 150-Watt 4-Channel Portable Sound System -
I need circuit diagram Passport portable sound system .to repair this unit.
My passport expired 9/5/2010 What forms do I need to fill in Thanks
Just fill out a normal passport renewal form at the US Post Office (it must be a post office that processes passports). Bring your old passport with you. If you are a minor, you must have both parents with you.
Jun 20, 2011 | Passport + Portable Personal Sound System...
How do i get a passport in the internet?
Passport as in... the travel document? You have to appear in person at some point but here's a site that may help:
http://travel.state.gov/passport/forms/forms_847.html
Jun 01, 2011 | Passport + Portable Personal Sound System...
What if I lost my 2nd passport to be renew can I use my very first passport?
Yes most governments accept the use of an old passport some charge more for the service though.
Mar 10, 2011 | Passport + Portable Personal Sound System...
Can a person verify that another persons passport is valid, not a counterfit?
What has this to do with a sound system?
Contact the government agency that issues passports and report the other person as using a fake passport. That should raise enough red flags to trap the offender (if he/she is) the next time they try to use it. Or, get a life.
Dec 14, 2010 | Passport + Portable Personal Sound System...
My WD Passport sounds like a machine running, but my computer doesn't recognise it. I also do not see the lights at the insertion site. Please help, Thanks, Naveen
The lights signal data transfer so no lights = no transfer. It's clear that the hard disk inside your Passport has failed and, since it can't be repaired, all the data was lost and the unit is dead.
Buy a new one.
Dec 11, 2010 | Western Digital WD Passport 250GB Portable...
Mistake in sur name of passport
Go to the passport office where your passport was issued. Take the documentation that you provided when you originally requested your passport. They should be able to remedy this.
Feb 26, 2010 | Passport + Portable Personal Sound System...
How do I open a fender passport 150 speaker cabinet?
There are screws running down the sides of the front panel which you will have to remove. The circuit board is secured to the front panel by the nuts, washers etc. that the controls and jacks are fastened with. Once you get the panel; loose gently move it forward so you can see any connections to the circuit board. Make careful note of all of these and draw diagrams. You will have to completely remove the panel from the enclosure and then the circuit board from the panel. The jack in question will be mounted on the circuit board and soldered to it on the reverse side. You will need to unsolder it, obtain an exact replacement, solder in the replacement and replace the board on the panel and the panel back in the enclosure. Make sure everything is connected exactly the way it was originally. Hope this helps.
May 23, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
The 'protect light' comes on Fender PD150 Portable Sound System
The protect circuit is activated by a current sensing transformer in the *input* of the power supply. If any of the subassemblies of the unit (or all of them in combination) draw excess current then the protect light will illuminate and the power supply shut down to prevent any damage to the system.
The circuitry in the power supply is fairly robust as well as fuse protected so it is unlikely that the power supply itself has failed. More than likely one of your output power transistors has been shorted and it is easy to check this yourself if you are interested in doing so.
Furthermore if you follow a few *simple* precautions you can do this safely and confidently.
Post again on this thread if you are interested and I will spew the details.
-BK
Nov 28, 2008 | Fender Passport Deluxe 500watt Sound...
Passport
i want to know the status of police verification for passport,ive aplied through chennai passport office
May 10, 2008 | Passport + Portable Personal Sound System...
Sharp wf 940 portable cassette / radio player
inside radio there is relay near power supply. change it and then radio will work. or clean it.
Mar 01, 2008 | Sharp CD-BA2600 CD Shelf System
Fender Passport 150 PRO 150-Watt 4-Channel Portable Sound System - Logo
214 people viewed this question
Top Fender Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rick Moore
Rick Moore
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
