Question about 1A Auto Parts 2003 Dodge Grand Caravan Tail Light Driver Side
2003 dodge caravan how to replace tail light - 1A Auto Parts 2003 Dodge Grand Caravan Tail Light Driver Side
The tail lights on my 2006 dodge grand caravan don't work. Any ideas as what could be wrong?
Check that the fuse is not blown and that there is no wiring fault. Otherwise check that the lights are not blown as well, and look at the following YT video to illustrate the removal of the light:
How To Install Replace Taillight Dodge Caravan Chrysler Town and Country...
Another useful link is:
Dodge Caravan Tail Light Bulbs Replacement Guide Brake Parking Signal...
Feb 12, 2015 | 2006 Dodge Grand Caravan
The tail lights on my 2006 dodge grand caravan don't work. Yet all the other lights do. I have replaced the light switch on dash but it did not fix the problem. Any ideas what could be wrong?
Get the wiring standard for trailer socket on car / caravan .
Something like this
http://www.caravantalk.co.uk/caravan-advice/new-to-caravanning/electrics-guide/12-volt-systems
Then get a 12v probe and test the voltage is coming out the correct pins on the car when the tail lights are turned on.
http://www.amazon.com/6-36V-Circuit-Test-Probe-Indicator/dp/B0065R1CK4
Check the Earth Connections on the caravans tail lights.
Check the Caravan has an earth connection to the car body.
https://caravanchronicles.files.wordpress.com/2012/01/caravanchronicles-wiring1.jpg
see how pin 3 shows an earth wire it would have a wire on car socket pin 3 going to the car body. If the earth wire is corroded or broken I think the tail lights on the caravan would not work. It may be a different pin on your setup .
2003 dodge caravan. Driverside park lamp and tail light don't work. Turn signals work. Brake light works.
replace bulb, park and tail is same bulb, if bulb is good just clean re install, you will actually see if the filament is broken or burned
Mar 16, 2014 | 2003 Dodge Caravan
2000 dodge caravan is blowing brake light fuse when pedal is depressed. there is no tow harness and remote starter brake wire has been cut to isolate it. brake switch has been replaced and both tail...
Check all the light "sockets" in the back,look for damaged wires, check the wire harness that goes to your tail end door for wire damage, you could try to reseat each bulb and when doing so look for corrosion in the light sockets. other than that,your center break light in back may have a control unit that may be bad and shorting out. you need to test things 1 by 1. good luck!
Sep 13, 2011 | 2003 Dodge Caravan
How to change a map light bulb on a 2003 dodge caravan
Go to this web page:
http://www.paulstravelpictures.com/Dodge-Caravan-Overhead-Map-Light-Bulb-Replacement-Guide/index.html
It has pics and step by step instructions!
Oct 11, 2010 | 2003 Dodge Caravan
How to change a rear turn signal lamp on a 2005 dodge caravan
I am including a couple of illustrations to better help with this replacement.
You will first need toe open the tail gate. then next to the tail light on the inside edge where the tail gate meets the seal you will see to plastic screw covers ( if still there) or two screws. You will need to remove these two screws , once removed the tail light will come out by lightly pulling outwards. Then simply depress the thumb clip on the bulb holder and remove.
May 25, 2010 | 2005 Dodge Caravan
2003 Dodge Neon - fuse to dash and tail lights
there could be a short somewhere in the wires
Mar 12, 2010 | 2003 Dodge Neon
How do I replace a tail light lens on a 2004 dodge caravan
have to replace tail light asm, open hatch remove 2 clips or screws they might have either,and gentle pull out and remove connector.good luck.
Oct 10, 2009 | 2004 Dodge Caravan
Replace 2005 Dodge Caravan Light
go in through the back to change a light. where the wires are coming out of the back their should be an away to disconnect and pull out with the light attached. or you can go to the auto parts store and im sure they can assist you
Jan 01, 2009 | 2000 Dodge Caravan
1A Auto Parts 2003 Dodge Grand Caravan Tail Light Driver Side Logo
261 people viewed this question
Top 1A Auto Parts Computers & Internet Experts
David Payne
David Payne
Are you a 1A Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
